Question about Refrigerators
Timer comes on and compressor starts up but goes off in 10 to 15 seconds
    President:
  • 2,468 Answers
Could be either the ptc overload relay on the compressor is weak or the compressor is locking up and drawing too much current and the ptc is shutting it off,have someone take a current reading when it starts and is running and see if its with in specs and if the current rises before it shuts down,you may be able to put on a "hard-start" kit on the compressor instead of throwing the unit out
Posted on May 14, 2010
Unit will not power up. interior light will come on, if power button is pressed but display will not come on.
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Apr 20, 2015 | Refrigerators
36" monogram stopped working. Compressor is cool and condensor fan is running.
Jan 24, 2015 | Refrigerators
Hill produce refrigerator , turn off compressor and stop cooling after 5,6 hours then don't start again, I must turn off and on the main power breaker then start working for 5,6 hours I need too repe
Dec 08, 2014 | Refrigerators
My kenmore run and stop after temp is ok but will not come back to run until i open the door o touch the control face them will do the same thing again ,they toll me to replace the defrost timer is this my...
Jul 03, 2014 | Kenmore Refrigerators
I have a large walkin freezer and the compressor and heat strip come on at the sametime, I have to disconnet the compressor when the defrost comes on. Im not sure what wire goes where.
Open following links for 8145-20 wiring diagram and resources:
http://waterheatertimer.org/images/8145-20-wiring-350.jpg
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145-20 is 240Volt defrost timer.
Heat strip and compressor should not activate at same time.
As a general rule heater connects to NO terminal 3 and compressor connects to NC terminal 4
NC terminal 3 compressor is on all the time until defrost cycle begins.
NO terminal 4 heat turns on when defrost cycle begins, and at same time NC terminal 3 compressor turns off.
At then end of the defrost cycle, NO terminal heat turns off and NC terminal 3 compressor turns on again.
Jun 29, 2011 | Paragon 8145-20 Defrost Timer
My kenmore side by side refrigator has stopped cooling on both sides, you can here is click like the compressor is trying to run it cliks about 1 or 2 seconds then clicks again like on and off.sounds to me...
if the first three numbers are 106. on the model number it sounds like the start device on the compressor is bad,part number 8201799 and it's around 55 bucks,unplug the machine,remove the bottom back panel,you'll see the compressor,there will be a metal clip,pop it off with a screw driver and then slide the start device off the compressor,if it smells burnt or if you shake it and hear pieces rattling around it's cooked,also there's a timer in the fridge side,when you first open the freezer door the fan should blow,if it doesn't the timer could be stuck in defrost,with a screw driver you can turn the timer until it clicks and it will come out of defrost,if it starts then you have a bad timer that's stuck in defrost,but i'd put my money on the start device if the clicking is coming from the compressor area and it's not starting,let me know how you make out and as long as it's warm unplug it so you don't damage the pins on the compressor
Nov 03, 2010 | Refrigerators
It will run for a very short time then turn off and if you turn the defrost timer till it clicks it turns back on
The defrost timer is sticking if it only clicks a couple times before it starts. Try turning off the frig. and play with the timer, you will hear a differance in the clicking. When it has a loud click it goes into defrost and then you will hear a second loud click and it will come out of defrost and the compressor will start.If you are only hearing one loud click when you have did this before you can just replace the timer.
Aug 05, 2009 | Maytag Refrigerators
Maytag has a recall for compressor relay update possible fire hazard stated on notice,tech comes out and does update,now fridge wont cool. tech states that adaptive defrost timer is bad,he jumped wires...
Check the cold control thermostat for continuity.(off/on switch)
When he bypasses the wires at the board ,he also bypasses the thermostat control.
Apr 08, 2009 | Refrigerators
KitchenAid ksrb25fkss01- fan runs, warm air circulates
Compressor change is probably more than you wish to tackle.
1) must be certified to work with refrigerant.
2) requires silver soldering and or silver brazing.
3) requires re-charging with refrigerant and this is critical and must be measured to the oz.
If it works fine when it re-starts we need to find out what is stopping the compressor. First guess is a defrost timer. The unit goes into defrost at pre-determined intervals, depending on the defrost timer. When it goes into defrost, compressor goes off, heaters come on, and a defrost cycle is initiated. Following this, the heaters go off, (usually by a t-stat and not time), and the compressor is allowed to run again. Changing the defrost timer, which is probably one of the least expensive components, is worth a try. No guarantee, but it is a better choice than the compressor. If the tech did any tests, did he say why the compressor was questionable? Since this happens once or twice a week, it sounds like the timer or at least it is coinciding with a typical defrost cycle. Here is a possible test, when you find it blowing warm air in the freezer, advance the timer 1/4 turn cw. See if the compressor comes on when you do this. That is probably more info that you were looking for, but this is worth a try.
How old is the unit?
Gary
Nov 30, 2008 | KitchenAid KSRS25IL Side by Side...
My Haier Mini Fridge comes on but keeps nothing cold. I defrosted in August and it worked for awhile and now it defrosted on its own and no longer gets cold.
This could be a bad defrost timer. See if the compressor is working. If it isn`t or only works sometimes. The defrost timer could be bad. When the frig goes into the defrost cycle, turns off the compressor. It may failing to turn the compressor back on after the defrost cycle. Since it stopped defrosting at one point and started again, the defrost timer may be bad. Let me know if this was any help or if I can help any farther.
Nov 12, 2008 | Haier Refrigerators
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
