Question about Whirlpool GS6NBEXRS Side by Side Refrigerator
Control lights are out - Whirlpool GS6NBEXRS Side by Side Refrigerator
  • John Tripp
    John Tripp May 14, 2010
    If you are saying that a GS6NBEXRS has a lighted digital display then I believe you have listed the wrong model number. Make sure you list correct model and the click on my name or another technician will assist you. Sea Breeze
    President:
  • 2,468 Answers
It's the main electronic control board in the lower rear area of the unit near the condenser fan,you need to unplug the harnesses connected to it and remove it from the plastic case its housed in
Posted on May 14, 2010
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Jul 09, 2015 | Hunter 52" Ceiling Fan With Light And...
My dreamgear chargepack works but when I but my sliver remote control in it lights up which means that its charging but when I try to charge my blue control the lights wont turn on. how do I make the light...
I have several controlers in several different colors, but "coincidently" several of the blue colored controls have had the LED lights stop working completely. I am begining to think that many blue colored Sixaxis PS3 controlers were made during a version that had problems with the LED lights going out and no longer working, or simply a bad batch of controlers.
Did you try letting it charge for a while, even if the ligfhts won't light up, then press and hold the PS3 button to check and see if it took the charge?
On my blue controlers, they still charge and still work, but none of the LED lights illuminate anymore.
Solution would be to buy a new controler, or ignore the lights not working.
Sep 20, 2013 | Video Game Consoles & Games
I HAVE 3 NOS DB IN DIFFERENT LOCATION FOR LIGHTING HOW TO MAKE 1 TIMER PANEL TO CONTROL THOSE 3 LOCATION OF DB
What is NOS DB?
You want to control 3 locations of lights using 1 control panel.
Are you going to run wire from each light to the control panel?
Are you using 120Volt or 240V? What voltage are you using?
Model number of control panel is unknown, and which timer is inside control panel is unknown. Copy following link for overview of control panels.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Aug 05, 2012 | Intermatic 40 Amp Control Panel & 220V...
Westek SLC6CFL programming instructions
Copy following link for Westek outdoor socket timer instructions:
http://waterheatertimer.org/pdf/Westek-SLC6CFL-timer-instructions.pdf
Jun 27, 2012 | Ace Hardware AMERICAN TACK 3236858...
Basically,i put in the usb of the xbox controller and it only shows 2 lights on the controller,no flashing jus on.its the 1st light on da left nd 2nd light on da right.help plz
Your xbox lights will light up and stay lit for each controller connected to your xbox.
If you have two lights on, that means two controllers are connected. (possibly your wired controller and a wireless controller) if you were to disconnect one of them, one light would go off.
Mar 21, 2011 | Video Game Consoles & Games
My oven light blew now my control panel on my stove doesnt light up but the burners work?
I have seen the control panel light fail while the temperature controller still operates. In many floor-standing stoves the control light is operated by a switch inside the temperature controller, so it can fail independently of the temperature control. The 'fix' is to replace the controller. The oven light blowing is more likely coincidental timing rather than being directly connected to the other fault.
Feb 28, 2010 | Kenmore Kitchen Ranges
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
What does the VSC light on the dash mean
The check engine light ,trac control light and VSC light are on. Does this normally represent a serious problem on a 2004 toyota solara?
May 20, 2009 | 2004 Toyota Solara
No head lights but all other lights work including
you have a bad lighting control module. $499 new, $250 from tascafordparts.com or less from ebay or car-part.com.
It is under dash above brake pedal.
Section 17-01: Lighting, Exterior 1995 Town Car, Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Lighting Control Module Removal and Installation
  1. Open hood. Disconnect battery ground cable .
  1. Disengage three pushpins and remove lower driver side instrument panel finish panel.
  1. Locate lighting control module above accelerator pedal.
  1. Disconnect bottom two electrical connectors from lighting control module.
  1. Remove two screws retaining LCM to bracket and unclip from bracket.
  1. Remove lighting control module from bracket and disconnect two remaining electrical connectors.
  1. To install, reverse Removal procedure. Check lighting control module for proper operation.
Mar 15, 2009 | 1995 Lincoln Town Car
Whirlpool GS6NBEXRS Side by Side Refrigerator Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
