Hi
Thanks for using FixYa. From what
you have described it seems the issue is with the power board or the main board
and we’ll need to check few things. When you open the unit up; take a look at
the power board-the board where the power cords/plugs goes into. You might see
some filter capacitors a little bulged up in the top-If this is the case-this
is your defective part(you can try to replace them-but some soldering equipment
is needed). If not, then probably the main board has gone bad. This is the other
board-where all the inputs are going into. All this is only recommended if you
have electrical expertise and know how to solder/re-solder components. Please
note that the TV components consists high voltages even when in off position. Please
do accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
I Have a problem With An Samsung DLP 50" Model- HLN5065W That Come On Well But There No Color At All. Can U Tell What Could Be The Problem
