Question about Refrigerators
I have a 1976 model Sears Coldspot that is making a girgling/grinding sound from the freezer area. I remove the fan cover plate and the fan was rotating ok but every so often it would hesitate and slow down. I remove the frozen food and put it in another unit I have. I was afraid that the temperature would fall and I'd lose my products. It seems to run continuously making that deep grinding sound. Any idseas?
    President:
  • 2,468 Answers
If the temp has risen,check and make sure its not stuck in defrost mode,if it is advance the defrost timer ahead so the compressor again starts and runs,the only other thing would be the motor that you said is slowing down is getting noisy bearings and make that grinding sound,the gurgling noise could be just freon/refrigerant moving through the evaporator coils in the freezer
Posted on May 14, 2010
Hi. I have a Kenmore Coldspot Model 106.79172990. There is a fan in the freezer which has just started to make a very loud sound when the fan is spinning. It sounds like a bearing problem. When I stick a...
. Yes to both questions . You're right about the bad bearing. Also you are right about the evaporator fan. Actually it is called a circulation fan . You'll have to remove the food and racks in the freezer compartment to access the evaporator cover area which is where the fan is located . Look carefully around the opening where the fan blade is for two screws . They will be Phillips or 5/16 hex screws . If you locate them as I've mentioned , before removing them , carefully pull the fan blade from the center close to the shaft straight out of and off of the motor shaft . Do this if possible before removing the screws . Then remove the screws which hold the motor assembly in place . You may have to twisted little bit and angle allowing each bracket mounting foot to clear the opening . There should be a connector you can uncouple the power leads with . If not , when you purchase the new motor , it should come with wire nuts to rewire the new motor into the existing power leads.
Feb 19, 2011 | Kenmore Refrigerators
Fridge doesn't col freezer is fine
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is usually the evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Jenn-Air JCD2295HES Side by Side...
My freezer is working but my fridge is not. GE its a side by side fridge with a freezer drawer.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area..
Nov 10, 2009 | Hoover HCA331FFK
Refrigerator area is not maintaining cold, freezer seems fine
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Kenmore Refrigerators
Whiring fan, very loud,last night now no sound and the temp is rising
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Samsung RS2556 Side by Side Refrigerator
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Fan is on but it is not cold could it be the compressor
The evaporator fan motor may be on but not spinning fast enough. They last 4-5 years.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Evaporator fan motor ($30).
Oct 31, 2009 | Refrigerators
Whirlpool model ed5chqxkbo1 wont cool
Oct 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sears ColdSpot model number 106 7649314
REplace the fan. The fan is most likely bent and will continue to have problems until it is replaced. You can get it at repairclinic.com
May 30, 2009 | Freezers
Ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
Apr 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
