Question about DISH Network 322 DTV Receiver
I bought a Dish remote for a2nd tv and cant get it
I bought a Dish remote for a 2nd tv and cant get it programed not in the room where the reciever is
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Strmason,
Are you still having problems with programming the remote to your receiver? I am assuming it is TV 1? You should have a green tab at the bottom of the remote with a "green 1" and no lettering after the 1. If you have the correct tab on the bottom, you should be on the "System Information" screen, showing on your TV, from the receiver. At the bottom of the screen you will have "primary and secondary remote addresses" with numbers in the white boxes. You can press the "record" button on the remote to address the remote to the receiver. I hope this helps.
Ray Calo
DISH Network
Posted on Jan 08, 2011
Remote will not work for t.v or dish reciever but batteries are good, lights still work but will not turn tv on or off or turn reciever on or off or even get a guide menu. please help
albertmjuras
Is this a new remote or the existing one? I have provided instructions on how to program the remote to your TV and to readdress the remote to your receiver. Select the model of the receiver you have, click on the link and the just follow the directions. The bottom portion of the page has links for TV codes to program the remote to your TV. If this doesn't work, you may need a new remote. I hope this helps.
Program remote to TV and receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Mar 01, 2011 | DISH Network IR Remote Control
Tip
DISH VIP612 Remote Code Scan
DISH Solo DVR VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  1. Turn the device you would like to control on.
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | DISH Network ViP 612
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
The dish network 2nd remote isn't working I put in a new code because we bought a new tv for that room. Now, i can use the dish remote to do everything without the tv remote but NOTHING works on dish...
Hello, you may have gotten this resolved already, but if not, here are some simple steps to get this resolved. Follow these simple steps on our website, and you will be good to go!!! For this also, you will want to be at TV1, in the system info screen. Menu twice with TV1 remote. :)
Becki Barned
DISH Network Customer Service
Nov 28, 2010 | DISH Network IR Remote Control
I bought a new Sony ex4/40 tv and programmed my DISH Network remote control for it. Everything works fine when the all the lights are on in the room. Can't change the channels or go to the guide function...
Hello, the problem that you are having is fairly simple to solve. The tv is causing interference with the remote. It sounds like you're at TV1, and TV1 remote is an IR remote. You need to get a UHF remote, and that will stop the interference so that you can continue to enjoy your tv! You can e-mail me at becki.barned@dishnetwork.com if you have any questions or concerns.
Becki Barned
Nov 03, 2010 | DISH Network IR Remote Control
Remote to TV 1 doesn't work - buttons light up, nothing happens
Press the number zero for 10 seconds and wait until the "remote wizard" pops up. Then just follow the instructions on how to program your remote to your receiver box.
Oct 20, 2009 | DISH Network IR Remote Control
Uhf pro 8.0
Problem has been resolved per customer.
Sep 21, 2008 | DISH Network IR Remote Control
DISH Network 322 DTV Receiver Logo
116 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
