Question about Nokia 3660
How to insert memory card?
How to insert memory card correctly?
    President:
  • Nokia Master
  • 1,118 Answers
Download its user guide from this location and search for 'Insert the memory card', on page 131.
Hope you are able to sort your problems out.
Cheers! Carlos
Posted on May 14, 2010
    Problem Solver:
  • 8 Answers
By checking the edges and the weithe of the memory before insating it.
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Mar 19, 2011 | Canon PowerShot S51S Digital Camera
I will put memory card in my mobile no memory card inserted
First of all,make sure that you're inserting the approved type of memory card.
According to nokia company,nokia N70 supports for RS-DV-MMC cards.
If you're using the correct card,make sure the card is clean enough.You can clean the card by using a soft dry cloath like cotton cloth-DO NOT USE ANY LIQUID-.
After doing so,re-insert the card and check.
If the above step doesn't helps,insert the cleaned memory card into a card reader and check whether the computer can open the card.If it can,backup all the data on the memory card and format the card.Then insert the card into the phone and do a format to the card againg via phone.After that you can restore the data back to the memory card.
If all the above methods didn't work,then may be your memory card is burned out..
Jan 11, 2011 | Nokia N70 Cellular Phone
How do I use Transcend microSD, 1GB in an Acer Aspire Lap top? I have found where to place the Adapter in the lap top but not sure how to place it in (which side up) and how to place the memory card into...
Turn the computer off.
Insert the card one way, until you feel resistance, and measure how much of the card sticks out.
Then, remove it, turn it over, and insert the card again, and measure again.
Remove the card.
The smaller measurement is the instance where you correctly inserted the card.
Turn the computer on.
Open "My Computer".
Correctly insert the card.
The "My Computer" window will update, in less than 30 seconds, to reflect that the card has been detected, and Windows has been configured to access the card.
Double-click the changed icon, to "open" the files/folders that exist on the card's memory.
Nov 23, 2010 | PNY 1GB microSD Memory Card
My 2gb sd memory card for camera is formatted.its
Please Check that card was inserted correctly If Not then insert it correctly!
If it's OK then check if on computer with the help of card reader!
if Card was OK Then Please Visit You Camera Service Center!!
Feb 07, 2010 | Fuji FinePix A350 Digital Camera
In my n73 phone even thought the memory card is inserted it displays insert memory card now what shld i do.
Try cleaning the connectors on the memory card. Check the card on a different phone or PC. Make sure the card is inserted correctly, right side up.
Aug 08, 2009 | Nokia Cell Phones
Memory card
wipe the leads cleanly and then insert the memory card...may be there contact leads are not sitting properly on the terminals..
Nov 28, 2008 | Cell Phones
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
Memory card nor inserted
Three things may go wrong.....
1. the memory card slot is defective
soln -- blow into the slot to remove any dirt. if the problem persists, go to nokia care centre, its better not to lay your hands there.
2. the memory card might not be inserted the correct way
soln -- insert it the correct way or maybe wipe it with a clean cloth.
3. there might be a software problem which might be hindering the phone from reading the memory card
soln -- do a firmware reload, through nokia pc suite
Aug 17, 2008 | Nokia N72 Cellular Phone
Wont accept xd picture card
Hi, tecnil
Device cannot detect files on the memory card.
Cause
The memory card might be missing or inserted incorrectly. Verify that the memory card is inserted correctly.
The files might not be in the correct format. To print from the device control panel, the files must be in the sRGB JPEG format. To print other formats, you must use a software program on your computer.
You might have inserted more than one memory card. Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
oke,
thx
cropp
Jan 08, 2008 | HP Photosmart 7450 InkJet Printer
Saving game problem
The memeory card is not inserted correctly,
you have to push it just a little more, after it has been inserted correctly u can save the games
Oct 24, 2007 | Sony PlayStation 2 (PS2) Console
Nokia 3660 Logo
57 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
