Question about Canon PIXMA MX310 All-In-One Printer
Pisma Mx310 printer - paper jam
Display says printer jam. Clear paper and then press ok. However I cant find paper jammed anywhere !!
I cant print, copy at all.
Please advise where I can look for invisible paper jams !!
Cheers
Tania
  • 7 more comments
  • julz6769 Apr 03, 2008
    Me too, twice! At first (couple weeks), it was loading the paper just fine. Then, out of the blue, it started grabbing it crooked, giving paper jam messages, etc. I was given a replacement printer last week after calling Canon. When I called Tech support, as soon as the guy found out what it was doing, he just took my address and mailed me a new printer, very easy and very polite BUT, Now, after two days, the new one is doing the exact same thing?! This must be a trend here!
  • Anonymous Sep 20, 2008
    Sad, think it has potential to be a great tool, however, same problem. At first, no problem printing, two weeks later, it grabs paper crooked. When investigating noticed that the feed roller is located on the right side, which is where it's pulling.
  • batmanface Nov 17, 2008
    ARUWHSFKLJSOFuopaKJSlAZYSDi!!!!!
    i hate it :]
    help me now before i set it on fire.
    AAAAAAAAAAHAHAHAHAHHAHAHAHAHAHA.
    =| *sniff*sniff*
    seriously. you'd think they would have a solution to this problem? good lord.
  • Anonymous Nov 18, 2008
    My printer is continuously saying paper jam, I have only just bought it and am having trouble getting through to cannon via telephone.
    There is no paper jam, what can I do?
  • Jangol Nov 27, 2008
    says it has a Paper Jam but there is no paper jam. Now it won't work only had the printer 1 month. How can I fix it?
  • Anonymous Nov 28, 2008
    pisma Mx310 printer - paper jam problem, and notify you when a new solution is offered.
  • Anonymous Jan 26, 2009
    Same problem.  Printer displays "Paper jam" when there is no paper in it.
  • Anonymous Apr 10, 2009
    I have a paper JAM ON MYCANNON MX310, how do I fix it?
  • cena06 May 22, 2009
    i have canon mx310 printer. it is getting problem with paper jam so how do i solve this problems
mickblu
  • 12 Answers
SOURCE: Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Posted on May 31, 2007
Mix-it-up
  • 832 Answers
SOURCE: paper jam, open back cover, then remove paper jam
Ther is some tiny little paper piece left in the machine! You will find it at the left hand side near the gear wheels ;-)
Posted on Jun 15, 2008
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
SOURCE: Canon MX310 paper jam
"Gclanton" had it right.
I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue.  I ended up finding an object lodged against the switch.  Needed a flashlight, plastic giftcard and a tweezers to get it out.  Works great now.
Posted on Jan 05, 2009
  • 260 Answers
SOURCE: oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Posted on Apr 09, 2009
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Keeps asking for paper and will not print
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
vote me if you find your solution
Aug 11, 2010 | Canon PIXMA MX310 All-In-One Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
I have an error code 5100 on a Cannon MX310 that will not allow me to print. Can you help please?
There are several things to check
1.remove and reinstall the ink cartidges
2. press ON/OFF switch to reset the printer
3. if the printer is new, make sure all the packing material has been removed
4. Check the paper path to make sure that you do not have a paper jam.
5. If these do not clear the problem, you need to have the printer serviced.
2. 3. Remove Packing Material MX310 4. Removing paper jams MX310 5. The MX310 may require repair
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper Jam
Most likely a bad or obstructed sensor. Use compressed air to blow around the top and back of the printer removing heavy paper dust and look under the pickup rollers for small pieces of ripped paper. If the sensor is bad, contact service and support.
Jul 29, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
515 people viewed this question
old marine
old marine
