Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
NEW MAYTAG MSD2652KGW 26 CU FT SIDE BY SIDE
JUST SET UP NEW REFRIG. HOOKED UP WATER LINE THAT WAS WORKING ON OLD REFRIG. INSTALLED FILTER PLUGGED IN AND NEW REFRIG IS WORKING AND COLD, BUT ITS NOT MAKING ICE AND WATER DISPENSER ISNT WORKING
    Champion:
  • 210 Answers
Disconect water line and make sure you have water pressure.
Posted on Jul 22, 2008
Ice maker set up
it takes a couple hours for ice and not as long for water to chill .
Feb 09, 2015 | Samsung 26 cu. ft. Side by Side...
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Jan 11, 2014 | Samsung RF4267HARS 27 cu.ft. French Door...
Ice and water tastes funny after I installed a rubber water hose
Discard the first few batches of ice made by the ice maker. If new plumbingconnections are installed, discard the first few batches of ice. The plumbingsystem is flushing and may cause a bad taste or odd color. Discard ice stored in the bin for long periods of time. Wash the ice binwith warm water and mild dish detergent. Dry thoroughly before replacing thebin. Place foods in airtight containers to prevent the transfer of odors.Thanks and hope it's helpful.
Feb 16, 2011 | Admiral 26 cu. ft. Side-By-Side...
In door water line plugged or froze up.
Whirlpool water lines do not plug or freeze . Replace the dual water inlet valve behind the refrig , where the wall water line connects to on the refrig .
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge acts like compressor is not coming on - Maytag wide by side - seven yrs. old
Pull the refrig out and remove the back panel . You should see the compressor and the cooling fan ( condenser fan ) . If the fan isn't working , it needs to be replaced . If the compressor isn't running or starts then cuts off , then the box plugged onto the side of the compressor , with 3 wires going to it ( overload/relay ) needs to be replaced .
Oct 31, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
Jul 20, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
I have replace my water and the waer has stopped
Remove the new filter and re-instal. If this doesn't solve problem I would put the old filter back in and try. If you now have water remove the old and try the new one again. Don't forget to push firmly as it may have not seated fully.
Jul 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
I have a Maytag side by side refrigerator and lost my manual. How do I remove the inside water filter cartridge, which rotates either direction but does not easily come off?
first shut of trhe water and then let the pressure off of the line by openoing up the water dispenser . then turn it counter clockwose and then it sjhould come right off
Dec 24, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Apr 23, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
272 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
