Question about Canon PIXMA Pro9000 InkJet Photo Printer
My Canon Pro9000 stopped printing anything on the paper. Goes through the motions of printing, but paper is blank. Just put in a new black cartridge, other cartridges have since run out in an effort to do deep cleaning, nozzle checks, etc.
    Brigadier General:
  • 10,406 Answers
Either pay $40 to $60 to have a qualified technician trouble-shoot the printer, or spend about the same amount to buy a new printer.
Or, if the printer is still under "warranty", then "exercise" the warranty.
Posted on May 14, 2010
My Canon Pizma Pro9000 prints photos that contain TOO MUCH black in it. All the colors appear to be much darker than on the screen. And when I lighten the pics, it doesn't help since all the shadows are...
Hi
I suggest you clean it manually by removing the ink cartridge and rub the print head into a paper with alochol and then run the print nozzle for 2 times to clear some ink residue that cause darken color
Mar 08, 2011 | Canon PIXMA Pro9000 Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
My Canon Pixma MP610 printer will not print. It
Possible causes: Empty cartridges or new cartridges with cover strip still on the contacts, plugged printhead, wipe with warm water on paper towel to see if all colors are there, also physicallyclean the black cartridge. Try to print. If not working, use the printhead clean and or prime in the printer's maintenance tab.
Mar 09, 2010 | Office Equipment & Supplies
I just put a new ink cartridge in my LexMark 5600/6600 printer and it does nothing and it worked just fine before. It will not print anything! Help!
You just printer will not print anything, you didn't tell us if the actually goes through the motions of printing but gives a blank sheet. The fact is these two uniquely different scenarios with different solutions.
So I will endeavour to give you both solutions.
Printer goes through the motions of printing but gives a blank sheet: This is indicative of blocked nuzzles.
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a place/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Printer does not go through the motions of printing but gives a blank sheet: Usually in this case the indicator lights just blink away.
This could be as a result of either of these scenarios.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Dec 07, 2009 | Lexmark P4350 All-In-One InkJet Printer
Black text not printing!
You need a new printhead, QY6-0063-000. The instructions are packed with the new printhead.
Feb 07, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Printer not printing
Try this. Push the copy and cancel buttons together for about 3 seconds. Then release. The printer should push a blank piece of paper through. Try to print.
Jul 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
Canon PIXMA  Pro9000 InkJet Photo Printer Logo
209 people viewed this question
old marine
old marine
