Question about HP Designjet Z6100 InkJet Printer
HP Z6100: Making Grinding Noise SYMPTOMS: when the printhead moves side to side, it makes a grinding noise TM states this leaves marks on the printed material
FatrCat
  • 9 Answers
SOURCE: HP 7130 Random grinding noise resulting in a stall
Filka, You are most likely beginning to experience issues with service station function usually created by the buildup of ink which becomes gelled and gooey, resulting in sticking parts. Two primary points of trouble can be involved; one very easy to see and reach- the other requires a fair amount of disassembly but once inside the job is not hard.
First, right on the edge of the service station (the black box beneath the carriage when it's parked on the right) you will see a narrow white wedge-shaped piece. This is a retracting "wiper" which is supposed to slide forward when the carriage is parked, and to the back when the carriage is preparing to move. It has a small rubber tab at the front edge which wipes ink from a gold contact surface right in front of the wiper. I've yet to see one truly do well at keeping the surface free of ink, but it does keep it from building up. It is quite easy for this wiper to become "glued in place" by all of this ink. Start by raising the maintenance door, causing the carriage to move out to the center and the wiper to retract(if they will). You can then use a dampened paper towel or cotton swabs to clean the contact in front of the wiper, then gently pull forward on the top of the wiper to slide it forward over the cleaned surface. This will remove some of the ink on the rubber tab and begin letting you clean the wiper itself.
The second area of trouble is the service station itself. The sleds and tray are likely to be heavily coated and the only real way to clear them is to disassemble the case for access. You can use the following link to go to a step-by-step photo/instruction guide that will show you exactly what's involved-
http://www.fatrcat.com/7100ss.html
Posted on Mar 12, 2008
SOURCE: grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Posted on Mar 25, 2008
aicaxz
  • 511 Answers
SOURCE: HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
Posted on May 29, 2009
seeker5211
  • 1089 Answers
SOURCE: my HP m3035 printer is making noise in the toner
Open the rear door. Power on the printer. Watch and listen as the fuser rotates. Does the noise occur when the fuser rotates? if yes - replace it. If you still think it's coming from the toner, remove the toner, close the toner door. When the motors start turning the noise should be gone. Insert the toner and listen again
Posted on Jan 30, 2010
  • 7 Answers
SOURCE: HP Color Laserjet 2840
You might find that it is the gear driving the fuser, these plastic gears get very worn when driving the ceramic fuser gear. Right Rear plate assembly RG5-7580 with the gears that connect the fuser motor to the fuser.
Posted on May 25, 2010
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Grinding Noise
It would probably be time for a new hard drive. You can try putting it in a plastic back and them put it in the freezer for an hour. Sometimes this gives you enough time to pull the data off. A drive recovery service would be the other option if the information on the drive is very important to you (Ontrack.com or Driversavers.com)
Dec 17, 2013 | United Stationers HP Designjet T1100ps 44...
Phaser 8570 makes grinding noise
Our Xerox 8580DN is making a grinding noise when starting up and then it doesn't start up it state that there's a jam.
Mar 12, 2013 | XEROX - COLOR PRINTERS COLORQUBE 8570/N...
Full lock grinding noise micra
A "CLICKING" NOISE WHEN TURNING USUALLY INDICATES A BAD CV JOINT. LOOK AT SIDE MAKING NOISE AT INNER AND OUTER CV RUBBER BOOTS...IF CRACKED OR TORN....PROBABLY NEED NEW CV JOINT
Jul 30, 2012 | Cars & Trucks
My tire is making grinding noise then drivers side tire blew, brake line. Roke and when I put spare tire on you can move the tire back and forth. Any ideas?
Your tire is making a grinding noise? Was your tire even turning when it blew? I sounds as though you have a wheel bearing going bad (or maybe even out). Install a new wheel bearing Chrysler vehicles are noted for this. Please rate my answer so I get point awarded.
Jan 18, 2012 | 2000 Dodge Durango
HP Officejet Pro 8500 Wireless All-In-One InkJet Printer Paper feed will not drop down every time, and is making a grinding noise. Is replacing that piece available?
Hi. You leave a question mark?
I don't understsand what you mean by Papaer feed will not "DROP DOWN"?
I to have the same printer, the paper feeds from the tray (s) from below.
A little more info please?
The grinding in the system trying to feed through the paper.
Just a thought, turn the printer round find the release levers and check the internals for paper jam.
Mar 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Hp laserjet 3330 gears on right side grinding after print
The most common problem with grinding is from compacted toner. Try changing the toner cartridge.
Aug 26, 2009 | Office Equipment & Supplies
Hp all-in-one printer, makes a grinding noise when turn on
My 928 printer makes a loud grinding noise when the ink moves accross to the right hand side, also the red coulor is not coming out onto the paper the cartrige is new
Jul 03, 2008 | Office Equipment & Supplies
Grinding noise on startup
OR
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
HP Designjet Z6100 InkJet Printer Logo
189 people viewed this question
Seeker5211
Seeker5211
