Question about Car Audio & Video
I have a ripspeed cmr 2000 cd mp3 player. Can you tell me if this car radio has the capabilty of using a CD muti changer?
AUTOSOUNDINS
  • 232 Answers
SOURCE: 1998 - 2002 Honda Cassette 6 disk CD changer Radio
the cd changer is malfunctioning, the factory cd changers usually don't last that long because of the heavy use and many mechanical puts
Posted on Aug 14, 2008
SOURCE: 2000 Lincoln Town Car Cartier CD Changer
My 2000 town car has a kenwood kcd-512c. but its only playing one track, which is what im looking for a solution to now :)
Posted on Sep 22, 2008
LVT7857
  • 116 Answers
SOURCE: Cd wont eject
You are absolutely right about bose! And GM Delco as well. Try this. I've had 50/50 results. Need 2 peole. One at the nattery, the other at the cd player. Turn the key on, radio will power up. with the radi powered up,disconnect the negative battery cable from veicle. Wait a few minutes. Now this step might be cumbersome. While holding stereo in your hand, push the eject button and HOLD while the other person re-connects the negative power cable back up. Ths will do a reset on the stereo and you may get lucky!
Don't put anymore cd' in it. Your only other option if you want that CD bad enough is to disassemble the case of the stereo and manually move the mechanism to eject it. Hope this helps
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
alicantecoli
  • 22219 Answers
SOURCE: 2004 Volkswagen Beetle Radio/CD player
new one with a usb connector and sd card reader is better and cheaper
Posted on Jan 31, 2009
  • 43 Answers
SOURCE: radio audio muted and cd changer gives message no cd changer c320
Hi, Joe here to help. The cd changer is at fault. You need to replace the changer. The system is on a fiber optic loop which cuts out the sound if can not complete that loop.
Posted on Apr 08, 2009
I have just bought a boat which has a alpine 7618r fitted but its not working can i slide a moden cd/mp3/usb replacement unit in there using existing wiring /speaker loom
Yes you can replace that unit however the harness that plugs into the old alpine in all probability will not work with another radio so you will have to connect the new radio's wiring harness to the boat's harness.
Aug 17, 2016 | Alpine 7618r Audiophile Car Headunit Tape...
My Lexus Rx33006 6 disc cd changer will not read mp3's. My question is what format does it support?
That one will be tough to find out for sure.. it most likely will not play back MP3 - very few CD Changers did. the dealership most likely will not know. There was only 1 CD changer ever made that I know of that played MP3's - a Sony.
Best bet is visit your local car audio specialist and have them show you some option to integrate your favorite MP3 player with your RX's radio.
Feb 04, 2011 | Car Audio & Video
I am a novice. If I buy a MP3/CD audio book that
Yes most newer cd player's are capable of playing mp3 music. My stereo plays them and its going on 10 years now. But if your not sure it sometimes says on the cd player mp3 if you have the vehicles orginal cd player, if it newer then 2000 you should be OK. :)
Sep 22, 2009 | Car Audio & Video
How do i return to my radio from my cassette? The eject button is broken.
Open it, try manual eject, if not look for the switch that monitor between cassette and radio mode, you can do manual connection or switch it manually.get it?
Aug 30, 2009 | Pyle Double Din AM/FM Cassette & CD Player...
I have a 2000 beetle with fixing in the boot for cd changer...will any changer do, not sure what i should be looking for! Thanks
Likely have a Monsoon radio system in your 2000 Beetle. The CD changer is controlled by your radio, and not any CD changer will connect to the outlet in your trunk. You can either find a CD changer on eBay (or elsewhere, or swap out your radio for a radio from a newer VW Beetle that has a CD player installed instead of the cassette. Can also find those on eBay.
Jun 10, 2009 | 2000 Volkswagen Beetle
Cassette adapter and MP3 not working
Usually a dirty tape head. I recommend adding a 3.5 jack to your radio through an fm modulator.
Apr 24, 2009 | Sanyo FXCD-500 RB CD/Cassette Receiver...
How to connect a panasonic cx-dp880 cd changer to a cd receiver
My records do not indicate that they are compatible but are unclear, there may be some special connector used, none is listed however. Although if the cd changer is not a direct plug in, you can use an FM modulator. This device plugs in between (or wireless ones sit near) the antenna and radio transmiting a signal of it's own usually around 88.5 or so. Your cd changer or any other audio device plugs in to the modulator and it transmits the audio signal via an FM radio station. You then tune in your radio to the designated frequency and you're done. The only problem is weather or not your cd changer has a controller built in to facilitate this type of install.
-Dynami
Apr 06, 2009 | Panasonic CQ-RX400U Car CD/ MP3 Player
Error 11 and 12
First try to clean the optical lens of the player. USe a cd disc cleaner for cleaning.
Hope tis initial info helps.
Nov 20, 2008 | Kenwood KDC-CPS89 10-Disc CD Changer
I have a Bose acoustic wave muti-disc changer.i have 5 disk in changer,i cannot eject any disk,& it looks like its hung up on # 5.non of the disk will play. Thank You-
I called Bose service. Jason said to unplug for 1minute then plug back in. If the changer does not reboot and operate properly....you call Bose service. They will exchange your cd changer for a new one.
$75 plus tax and return your cd's to you. They will give instructions for the exchange when you call.
Aug 22, 2008 | Bose Acoustic Wave (32022) 5-Disc CD...
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
