Question about Maytag Atlantis MAV6000 Top Load Washer
Not draining after rinse cycle
My Maytag atlantis washing machine is not draining after the rinse cycle. When I adjust the dial to rinse (for a second time) it drains and spins dry.
    President:
  • 2,468 Answers
Replace the timer it has a bad spot inside of it in this segment of the timer and isn't passing voltage for spin,when you forward it then it gets power again,they do wear out too
Posted on May 14, 2010
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
Apr 04, 2009 | Maytag Atlantis MAV7000
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis washing machine
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Feb 13, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
500 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
