Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
I also deal with soot everywhere. I have propane. We do have a chimney that we vent when using. Still soot.
  • 8,404 Answers
Soot is a sign of too much gas and not enough air. Have your propane supplier make proper addjustments.
Posted on May 16, 2010
I have a Char-Broil vertical propane smoker. The past 3 times I have used it, well, my food has black soot all over it! I have to wipe it all off the food before we can eat it. I have the top vent open and...
The propane burner has a slide opening somewhere before the burner so the gas/air mixture can be adjusted to burn better and hotter. you get alot of soot because the gas is too rich, it needs more air mixed in before the burner. the air vent on top and bottom of the chamber has nothing to do with the gas/air mixture to the burner.
Sep 21, 2011 | Grilling
Can I vent my ultra v tech 80 propane gas furnance with pvc so I can do away with chimney
Generally, the furnace must be at least 90+ efficiency to be able to use PVC pipe. In addition, high efficiency gas furnaces require a condensation pump, to pump excess moisture out of the furnace. If yours has always been venting up a vent pipe, then NO, you can't use PVC pipe.
Hope this helps you.
Mar 14, 2011 | Heating & Cooling
I have a black soot on all my walls through the whole house especially the exterior walls. I believe it is caused by my propane fireplace. Im not sure if it is not ventilating properly or what the problem...
Is a Vented or Vent-free gas fireplace? I really suspect it's Vent-free (ventless) as a vented unit, unless the direct vent is clogged exhaust everything, including 85% of the heat out side.
Here are the things that will cause a Vent-free Gas Fireplace to soot.
  • Not having the fireplace cleaned and serviced, at least annually by a qualified technician.
  • Misplaced logs that impinge the main burner flames.
  • Running a ceiling fan at the wrong speed and in the wrong direction while fireplace is burning.
  • Burning scented candles while burning the fireplace.
  • Low Gas Pressure to the burner.
Here are the solutions to the above listed causes:
  • Have the fireplace cleaned and serviced.
  • Check your Owners Manual concerning the proper placement of each log,
  • Run the ceiling fan Counter Clockwise and at the slowest speed. The fan on the side of the switch should be in the UP position for Winter and Down for Summer.
  • Scented candles soot any way. Add the warm moist heat of the Gas Fireplace and they'll soot 50 times worse. The scent is not natural, it has an alcohol base like after shave & cologne. Stop burning scented candles. It has been proven that they greatly contribute to indoor air pollution.
  • Low gas pressure causes incomplete combustion, which causes the burner to soot. Have it checked by your propane provider.
Based on my 15 years in the hearth and home business and having sold and installed hundreds of these appliances, I am will to bet, it's a cleaning and servicing issue or misplaced logs.
Hope this helps you solve your sooting problem. I woud really like to know how it works out for you.
Please let me know at americanhearthandhome1@yahoo.com
Thanks ... Rich
Feb 16, 2011 | Heating & Cooling
My propane fireplace has recently began to produce black soot that is coming out of the fireplace and covering the walls and ceiling. This has never been a problem in the past and I really need to know...
Hi, sounds like you could have an obstruction. Check the entire stack for bird nesting materials or debris. The propane, when it burns, should not produce any soot. My guess is that something else is burning in your chimney stack and if it is blocked, it will come into you room. Once you remove the debris, you should attach some wire mesh around the exit to avoid any heat seeking animals from nesting again. Hope this helps.
Dec 21, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
Gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Sep 12, 2009 | Whirlpool LGR5636L Gas Dryer
Propane grill leaves soot on everything
Change your gas regulator and connecting kit if it is more than a year old and living outside. The other possibility is, that if the unit is older, the burner holes have rotted out and become too large. Most grills have replacement burners readily available. Deal with the problem in the order I have presented the solutions and it should be just fine.
May 08, 2009 | Grilling
Hayward H400 runs for 2 minutes and turn off, flames out chimney
Soot on your heat exchanger would explain this. Or leaves or rat nests would do the same thing. You can clean these yourself or get a repairman to do this for you. Just be sure if you have soot on the exchanger use a stiff bristel brush but not a wire brush. The soot as you free it up will be pouder and can explode in a fashion. Be careful and good luck.
Apr 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Black sot from vent free gas fireplace
Thanks for your question,
your problem is either impingement on your log set, or a product of incomplete combustion, if you notice soot on your logs, then you will need to take them out, clean them, and reinstall them as to not have the flame touching them, you will need to clean the burners as well, make sure nothing is laying across the burners, as this too will cause sooting, as far as incomplete combustion, was this model a natural gas converted to propane or the other way around ? if so who ever converted it, did they adjust the gas valve according to specs? improper adjustment will cause sooting or hooking up a natural gas unit to propane will do this too, I will recommend using (Rutland White Off) to remove any soot from your glass, it works fantastic for this ! any ace hardware will carry it, please do not use windex or any other cleaner on the glass as it will more than likely leave a rainbow affect on your glass once the glass heats up, hope this was helpful to ya, please rate this solution, thanks agai
mr.grzz
Jan 25, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
Dec 22, 2008 | Empire DV-215 Direct Vent Natural Gas...
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
310 people viewed this question
Top Napoleon Pool & Spa Experts
paulcarew
Gene Haynes
Dan Webster
Dan Webster
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
