How can I fix my printer laserjet 5000, I'm trying to print something biger and tha printer display come up with "20 insufisient memory" so I don't know if I have to clean the memory or to add more memory, please helmp my up. Thank you.
  • Juan Verdugo May 20, 2010
    Yes, it was very helpful, thank you very much Ekse
  • 13,433 Answers
Perform a reset and see if the issue gets solved.
Cold reset
  1. Turn printer off.
  2. Hold the GO key
  3. Turn printer on.
  4. Continue to hold the GO key until the printer reads COLD RESET.
  5. Release GO.
    • INITIALIZING appears.
    • Then, RESTORING FACTORY SETTING.
    • Followed by OFFLINE.
  6. Press the GO key to put back on line. NOTE: A cold reset resets the HP Jetdirect card. Remove HP Jetdirect card before performing a cold reset
Posted on May 14, 2010
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    HP Laserjet M2727nf Mfp error code 20
    An error 20 means that there isn't enough memory to print what you want to print.
    You will have to add more memory or simplify the print job.
    Dec 09, 2011 | HP Laserjet M2727nf Multifunction Printer
    PRINTER HP 3050 IS DISPLAYING LOW MEMORY AND IS NOT PRINTING UNLESS YOU CLICK ON THE TICK BUTTON.
    Press cancel on the printer and print something else.
    Whatever you were trying to print is sucking all the memory resources from the printer.
    Feb 18, 2011 | HP LaserJet 3050 All-In-One Printer
    My hp laserjet 4 plus tells me i'm out of memory
    Try this:
    20 MEM OVERFLOW
    20 INSUFFICIENT
    MEMORY
    Indicates a memory overflow. Too much data is being sent
    to the printer and the printer has run out of memory.
    Pressing the [Continue]* key causes the printer to print only
    the information it received. If the error persists, it may be
    necessary to simplify the print job (such as fewer fonts and
    less graphics information), or have the customer purchase
    additional memory.
    Jan 28, 2011 | HP LaserJet 4 plus Printer
    HP Printer not printing, activated error code -20
    Error 20 Memory Overflow / Insufficient Memory
    • A large print job has exceeded the memory capacity of the printer. Verify that the SIMMS or memory cards are seated. Add more memory or simplify the print job. Remember the original HP Laserjet has only 128K of memory available, the LJ+ has only 512K and neither one is really upgradable.
    • On the 5P turn the image adapt and page protect to ON or AUTO. These can be set within the Remote Control Panel. Press GO to resume printing.
    • On the 5L, set the Enhanced I/O to AUTO (PCL mode) and resend the print job
    Nov 24, 2009 | HP Office Equipment & Supplies
    Laserjet 2420d just keeps printing document repeatedly from XP
    check hp for latest driver for your operating system, also check if there is a PCL and PS driver. PS is better for PDF. sometimes an adobe update can cause these issues so if you cannot find a driver update you could roll back adobe to see if that fixes your issue.
    Aug 07, 2009 | HP LaserJet 2420 Printer
    Laserjet 5000 printing problems
    HP Laserjet 5000 Printer
    01.Try to install the catridge properly once again after rebooting the Desktop / Laptop along with this Printer.
    02. Check through CONTROL PANEL whether this particular HP laserjet 5000 printer is showing in the printer menu.
    03. If is there, try to remove offline and make online.
    04. If this HP Laserjet not available in the Printer menu, please insert the Printer driver cd and install this printer.
    05. Try to ensure your desktop or laptop not affected with Virus. There might be a change, if the machine is virus affected, Printer offline problem will be shown.
    Have a good day.
    Jul 17, 2009 | HP LaserJet 5000n Printer
    HP laserJet 5000 Printer continually printing same page
    laserjet 5000 printer A4 size printing right side line not printing .why?
    Jan 14, 2009 | HP LaserJet 5000 Printer
    NO RESPONSE, PRINTER DISPLAY BLANK
    sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
    Engine Test Button Location HP laserjet printer 5000 series
    The engine test verifies that the print engine is functioning correctly.
    The Formatter PCA is completely bypassed during an engine test.
    This test is very useful for isolating printer problems. The engine test
    prints a full page of lines across the entire printable area, and is also
    useful for checking and adjusting registration.
    laserjet-5000-engine-test.jpg Note Engine test will print from the last input tray used.
    If the last input tray is empty or if the last input source was the duplexer,
    then the Engine Test will print from Tray 2 (standard 250 CST).
    If Tray 2 is empty (and the last input tray is empty or the last input source
    was the duplexer), then the Engine Test will not function.
    Printing an Engine Test HP laserjet printers 5000 series
    To print an engine test, use a non-metallic object (such as a pencil) to
    press the engine test button. A single test page with horizontal lines
    will be printed. To print multiple test pages, hold down the engine test
    button.
    If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
    Inkworks
    Sep 05, 2007 | HP LaserJet 5000 Printer
    24 people viewed this question
    k24674
    jasbo
    jasbo
