Question about Sewing Machines
There is nosie from my bobbin and the thread is
There is noise from my bobbin and the thread is all wadded up on the bottom side when I try to sew.
    Problem Solver:
  • 13 Answers
Remove bobbin , clean out bird nest, make sure bobbin is unwinding the right way. Mine comes off the bobbin in a counter clockwise direction. It sounds to me like it wasn't threaded correctly
Posted on May 14, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
Husqvarna classica 105 - won't sew - thread wads up in bobbin area
this is a problem from the needle thread tension not tight enough
tighten the thread tension right up
Aug 08, 2016 | Husqvarna Sewing Machines
I recently bought a Singer 1507, I sewed few seams and then the thread tangled underneath, the needle stuck and it took some time to free it. I was unable to fix the problem even going through all p
It is most likely the bobbin not right I'll send u a pic also make such it's not in reverse after u insert the bobbin hand turn it one the need will go down and pic up the bobbin thread once it does pull up on needle thread and it will come up with it all way start with bottom and top thread out the back also make sure tension is set or it will wad up
/uploads/images/recently-bought-singer-1507-sewed-few-34846443-1-1.png
Jan 06, 2015 | Singer 1507
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
I have trouble with loading my bobbin. Sometimes it works and sometimes it does not. Last night I was sewing for quite a while and all of a sudden, the machine felt like something dropped and I quit sewing...
1.have you checked the bobbin to see if it's warped
2.have you checked for lint in the bobbin area & under the needle plate
3.you said the machine felt like something dropped,, did the machine make a nosie?
4.have you checked the needle to see if it's bent or damaged
5.have you had it maintenanced lately
Jul 29, 2010 | Brother Sewing Machines
14SH654: Singer 247 Machine runs fine and then bottom bobbi...
Try using a style 60 or 66 bobbin. I had the same problem at first, and someone on-line suggested the different bobbin. I use a style 66; instead of having a flat bottom and top (and all those holes), it's shaped something like a bagel. Now my machine works beautifully.
May 16, 2010 | Singer 14SH654
I have a Bernina 1008 and I love it, but every time I try to sew with it lately, the bottom thread wads up and makes a terrible mess. It will sew OK for a little bit and then the bobbin thread sort of...
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Rick
Sep 30, 2009 | Bernina 1008
Old Kenmore 158. bobbin issues, thread clumping and such
problem is always on the opposite side of the fabric, in your case the machine is not threaded properly.
Apr 24, 2009 | Kenmore 16622 Mechanical Sewing Machine
Consew 226 r sewing machine
do you have the user manual?
Sep 15, 2008 | Consew 206RB
Sewing Machines Logo
63 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
