Question about Proview PL916S2 Monitor
I have monitor PL916s manuf. Jan 2006. Left side
I have monitor PL916s manuf. Jan 2006. Left side went to a lower intensity that the right side. It appears to me that a bulb may have burned out on the left side (can still see but much lower intensity than right side).
If so where can I get a bulb and instructions to replace?
  • 11,361 Answers
You may have bad solder connection at the end of the lamp assembly, but you should also check the caps in the power supply/Inverter board aslo.
You can get lamps from: http://www.lcdparts.net
You can look at my albums to see what bad lamps look like:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Proview Master
  • 848 Answers
I have monitor PL916s manuf. Jan 2006. Left side? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0088 Proview 860 ALZ M713W Power Supply for PL916S
Posted on Nov 30, 2014
Need diagram
There is a 9 pin near below at the sata socket .
the upper pin 1 and 2 pin in left going right side are for power led light. and the 3 and 4 pin is for power switch.
the lower side are the same position but 5 pins.
lower 1 and second pin is for hdd led, the 3 and 4 pin is for reset switch. forget about the last pin, it must be empty
look like this ::::.
start the count from left to right.
do not start from upper to lower
Posted on Jan 09, 2015
Jan 29, 2014 | Foxconn RS740M03A1-8EKRS2H 2 x Ddr2 Mb
Product NO. PL916s Model NO. 900P I have a Proview monitor, which has always worked wonderfully. Recently my computer broke down and I'm using another computer with a small screen. I have misplaced...
Product NO. PL916s Model NO? This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
Jul 21, 2011 | Proview PL916S2 Monitor
My Proview monitor PL916s model# 900P built in 2004 suddenly shut off and will not turn back on. There were no previous problems with it and this is the 2nd monitor (same brand and model) which has done...
My Proview monitor PL916s model? This trouble maybe power supply or inverter boards is defective.
Apr 12, 2011 | Proview PL916S2 Monitor
Where can you get a power supply for a proview pl916s monitor
Where can you get a power supply for a proview pl916s monitor? This trouble maybe power supply or inverter boards is defective.
Oct 04, 2009 | Computers & Internet
I have Monitor Proview PL916S 900P It turns on
spc12b, Have you tried the flashlight test yet? How old is this monitor? Your monitor has a 2 types of power supplys in it. A switch-mode-power-supply and an "INVERTER" supply. One or both of them could be having a problem. The inverter needs DC from the smps to change it into AC to light up the cold-cathode-fluorescent-tubes that are hung in back of the lcd panel. Let me know results of flashlight test. After screen goes black, hold light 1-2" from screen at different angles. Let me know if you still can see the win-desktop screen even though it is still dark.. Bye for now. louie12fix on fixya or lmistyrel @aol.com
Aug 12, 2009 | Proview PL916S2 Monitor
Brake light problem Corolla 97
the tail light and brake lights are working from double contact bulbs. check the grounding, you dont have enough ground from one of the bulbs
May 30, 2009 | 1997 Toyota Corolla
When dim head light is turned on, right side brake light is on with high intensity. When brake is applied, the right side brake light is still on. Meanwhile left side brake light behaves normally-dim head...
sounds like you may have a bad brake light switch i think you problem will go away if you change it out. hope this has been of some help to you !
Pl916s proview 19 inch flat screen moniter
I managed to solve the same problem by replacing the six 470uf 25v capacitors. I have notice that the old ones has a bulging top.
Feb 07, 2009 | Proview PL916S2 Monitor
Frig and Freezer not working.
Beware I bought a Frigidaire side by side in 2006 and the compressor went out in March 2008, the warranty was out in Jan, and the repair man came out and said it was a 2004 model, you might have the same one as I had, they know the compressors are bad in the frig's and you only pay,$160.something if I remember. It sounds just like the problem I had, good luck!
Mar 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Monitor dark PRoview PL916s
try to contact an expert technician of monitor maybe there is a part of your monitor that is already defective, the controller of brightness and contrast.
Jan 14, 2008 | Computers & Internet
Proview PL916S2 Monitor Logo
144 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
