Question about Lexmark X3650 Printer
My camera memory card is stuck in the slot. Is there a way to remove it?
It should be a simple fix. Just a take a small jewelers screwdriver and gently lift it out. That's how i got mine out.
Posted on Jun 13, 2010
I can not insert the memory card into my camera
Card slot should be on the right. Make sure you have the correct type of memory card. a SD SDHC or SDXC. They should be 1"x 1.25" or 25mmx32mm. Ensure there is no card in the slot. insert as per pic inside the door with cutoff corner end first and facing up.
once securely in, to remove depress it a little and it should pop back out.
Note if the card does go in but cannot be written to, there may be a write lock slide on the side of the card. up is unlocked.
If you are still stuck then I would stop by a camera shop they should be able to sort you in seconds.
Oct 26, 2013 | Canon EOS 600D Rebel T3i Digital Camera
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
How can I tranfer video from my camera DMCTZ10
Once you connect the Camera to the computer, you will get the Camera as a removable drive under My Computer. You can open the removable drive to see the pictures stored in the Camera/Memory Card.
If the Operating System installed in your Computer still needs a driver, you may use the Memory Card slot on the Computer to transfer the pictures. Please follow the steps to transfer pictures using Memory Card Reader in the Computer:
  • Remove the Memory Card from the Camera.
  • Insert it in the Memory Card slot in the Computer.
  • Open the pop up window or find out the removable drive under My Computer.
  • Copy the required files to a folder in the Computer.
Note : Most of the Notebooks comes with its own Memory Card Slot. If it does not, you may get one from the market without much spending.
Thanks for understanding.
Please let me know if you need further assistance
Mar 05, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
I know this sounds odd, but my MEMORY card is stuck in my Nokia 5230 Nuron. I know the difference between the memory card and the SIM card. I followed the instructions in the booklet and simply push the...
I had a similar problem with a high capacity SD card in my digital camera. You'll need to use a tweezers to get it out the first several times and after that it should loosen up through wear on the plastic casing of the memory card (this is normal and will not hurt the card). Before removing the card with the tweezers nake sure to push the card so it is in "remove" or out position so it will be ready to re-insert.
Oct 31, 2010 | Nokia 5230 Cell Phone
Stuck Media Card in the Machine
same thing happened here. Hubby was able to remove memory card by inserting a VERY small screwdriver under the memory card and catching on an indentation. He was then able to remove the disk from the slot.
Jun 05, 2008 | Toshiba Satellite M45-S331 Notebook
Canon Powershot A75 faulty memory card slot
It's possible a pin is bent on the connector in the camera. A good eye and a good flashlight and you may be able to confirm.
Apr 13, 2008 | Canon PowerShot A75 Digital Camera
Memory stick stuck in the slot
Turn OFF the laptop and remove the battery. Try using a Paperclip or if you dare, open the laptop and you can get the memory card easier that way.
Apr 07, 2008 | Acer Aspire 5100 Notebook
Memory card stuck in camera slot
No need for pliers! I was able to eject the memory card by sliding a packing knife along the edge of the memory card. The blade was very thin, narrow, and long. I'm not sure if a regular box cutting knife blade would do. I've been able to eject the memory card with ease about a dozen times using this method.
Since I can't eject the SD card on the go, I use the USB cable to download images from the camera. Glad to know I can remove this when absolutely necessary, but sure wish I could remove anytime I'd like.
Jason
Jan 24, 2008 | Samsung Digimax 4010 Digital Camera
Lexmark X3650 Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
