Question about Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 34073 mower - stripped spindle-shaft?
Tried changing blades, but one came loose when engaged and the blades crashed into each other. Now, replacing the damaged blades, one won't tighten.It feels like it's getting tighter, then it releases. Stripped?
  • 5,568 Answers
Bet on it- you might try adding an additional nut of the right size/thread or several washers to utilize the remaining healthy threads.
Posted on May 14, 2010
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Ran over a tree root and bent a blade. Replaced blades. Checked belts. Belts are fitting loosely. Mower won't shift into gear fwd. or bkwd. Transmission not engaging. What might be the problem?
The gear would, obviously, have been engaged when you hit the root. I presume this will have caused some resistance in the friction material of your transmission. Consider the engine rotating the trans and the root stopping it from rotating, the transmission and the blade will have borne the brunt . Have your transmission checked for damage
Jul 16, 2015 | Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Troy bilt lawn mower
sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Jul 13, 2013 | Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
One blade is grinding the dirt when they are engaged
First check for a bent blade Then check for a broken spindle. Then check for broken metal on the deck or a broken/ disconnected deck hanger.
Oct 24, 2012 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Troy Bilt 5.5hp Self Propelled Mower Logo
387 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
