Question about Kenmore Elite HE4 Electric Dryer
Dryer won't heat, where are the fuses located at?
  • 5,911 Answers
If your dryer runs, but does NOT heat, the following two links explain how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
On a Whirlpool Duet series dryer, the heating circuits are located inside the unit under the drum on the right hand side. You need to remove the lower toe panel under the door to access. Locate and remove the screws under the bottom front edge of the panel and it will drop down, then come off. You may have to prop the two front feet of the unit up for better access. Placing a 2x4 under the front feet works well for this.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals (farthest to the back of the dryer). The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is not the heating element. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Repairclinic.com has a repair manual that you can purchase that will also help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
Posted on May 14, 2010
Duet sport electric dryer won't heat or spin, minute counter counts down
You will need to replace the "thermal fuse" located on the back of the dryer. Here is the part to order.
Nov 22, 2012 | Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Hoover VHW654D-80 not heating
    see the causes, and proceed. God bless you
    Heating Element
    hermal Fuse
    Thermostat
    Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Sep 22, 2012 | Washing Machines
    Where is the fuse located ?
    The fuse is located on the blower housing next to the thermister (heat control). You won't see it till you get filter housing off there:
    The 3 vid down shows how to get into it HERE on my blog
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Jul 07, 2012 | Kenmore Elite HE4 Electric Dryer
    My dryer won't heat and the timer won't advance. I already replaced the thermostat but that didn't fix the problem
    Hi christarn1
    Here are a few things to check:
    ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
    Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
    Check your Wiring
    Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
    Check the Door Switch
    If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
    Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
    Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
    You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
    If the heating coil is ok, then:
    You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
    If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
    If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
    then you do not have to tape the wires together as described above.
    To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
    DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
    Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
    If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
    You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
    A vent clogged with lint can cause it to overheat.
    Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
    If the vent's clogged, that new element can burn out very quickly.
    For video and pictures on how to replace a generic element go to the following website:
    davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
    Please take time to rate me thumbs up
    Sep 14, 2011 | Whirlpool Dryers
    Electric dryer won,t heat/replaced heating element last year,dryer worksbut won't hea
    Hi galepezz...
    Check your Wiring
    You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
    To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
    If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
    Jul 25, 2011 | Kenmore 62602 Electric Dryer
    Hi galepezz...
    Check your Wiring
    Jul 25, 2011 | Kenmore Dryers
    Dryer runs but doesnt get hot
    Hi, If you have a gas dryer2_bing.gif.
    The most common problem with a gas and no heat is the ignitor going bad...
    Here is a tip that I wrote about that problem...
    Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
    http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
    If your dryer2_bing.gif is electric2_bing.gif..
    There could be a number of different problems...
    Check out this tip that I wrote about this problem...
    Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
    http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
    heatman101
    May 12, 2010 | Kenmore 800 7983 Dryer
    Dryer won't heat up
    I would check the thermal fuse. It usually located inside the back of the dryer close or attached to the exhaust duct. It is about an inch long. Check it for continuity. If it has none, replace it.
    Another common problem is for the main wiring connection from the house, at the dryer, to burn and break it's connection. Because the dryer can still tumble with partial power, the connection may be only partially faulty. Check the main dryer cord for continuity as well.
    Hope this helped you and best wishes.
    Jul 26, 2009 | Dryers
    Dryer won,t heat, put in new element and still won,t heat.
    check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
    Apr 08, 2009 | Dryers
    Kenmore Elite HE4 Electric Dryer Logo
    203 people viewed this question
    Top Kenmore Dryers Experts
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
