Question about Sanyo DP26649 26 in. TV
Ccfl dark, F2 open - Sanyo DP26649 26 in. TV
  • 84 Answers
Replace f2
Posted on Sep 12, 2010
Hp compaq le1711 too dark with image troubleshooting
what is that?
a very old LCD monitor
too dark
need help.
turn up the brightness , as the OSD menu
see those buttons. on front of Monitor. push them see OSD
then push brightness up.
if still dim the CCFL lamps for the back lamps are now old and DIM
as all do and are now BAD.
HP does not sell parts for this old of monitor. if bad.
this is your PS moduel in side
the lift jacks 1 runs the CCFL light tubes. for back lighting
all CCFL go dim and yellow with age.
Jul 26, 2017 | HP Computers & Internet
L1900e dark backlight
1st try to check circuit that is operating CCFL, otherwise replace CCFL , it does not look like ccfl problem
Apr 12, 2014 | Samsung Computers & Internet
My laptop screen is dark but I can still see something but very vaguely
The screen displays is dark/ dim because there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. Either of the parts can be faulty or in some rare cases both. But most likely it is the CCFL (Lamp). Its life is limited and depending upon how long it has been in use, you can have a better idea - if its the CCFL or Inverter.
(Rest assure that your system is ok and you can check it by connecting you laptop with some external display, which would work fine)
So, my advice is that you get it properly checked by any professional for replacement of CCFL.
Hope it helps! Good Luck!
CreativeTECH
Feb 22, 2011 | ASUS F3F Notebook
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 08, 2011 | Computers & Internet
Screen dark but can still see picture
could be a problem with the inverter board which is the power board for the CCFL backlight system. if the tv doesnt actually go into shutdown you may be able to still see the video but it will be very dark no glow to the screen at all. the reasons for shutdown for inverter failure could be a bad inverter transformer or open fuse on the inverter that supplies power to the board or it could even be a bad CCFL lamp. i suggest looking for the fuse that is the most likely suspect it may be yellow if i remember correctly. good luck
Jan 18, 2011 | Sony KDL-32M3000 32 in. LCD Television
My delle173fpc powers up then goes dark if i swittch it off then back on it will come on for a few seconds then go dark again
You could have a faulty inverter board that supplies high voltage to the CCFL lamp or a faulty CCFL lamp.
Check out LCD Parts for service, parts and DIY info. click on this link to their WEB site :-
www.lcdparts.net
Nov 05, 2009 | Dell E173FP 17" LCD Monitor
Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
My Dell Inspiron 1300 wont start
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 09, 2009 | Dell Inspiron 1300 Notebook
Acer screen looks dark?
  • Picture flickering with dim display.
Apr 23, 2009 | Acer Aspire 5315 Notebook
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 07, 2009 | Acer Aspire 5040 Notebook
Sanyo DP26649 26 in. TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
