Question about Krups Super Automatic XP 9000 Espresso Machine
Krups xp9000 will not brew, but grinds beans.
I also have the same problem with my xp9000. The beans are grinding but no coffee is expressed.... Any advice????
Posted on May 30, 2010
  • leighmarkroh Aug 22, 2011
    Same here, looks like I will have to send back to the krups for a service, which I only did a month ago for a similar problem. It grinds beans and places them in the drip tray, I turn off, set cleaning programme, reset all the levels, cleaned it out entirely as per manual. It started working, but then after turning off, next morning same thing. What am I missing?
Mike I have the same problems. Do you have any solution?
Posted on Jan 25, 2015
    Problem Solver:
  • 6 Answers
Likewise, seems to be a common problem, someone must know how to fix this>?? Ive tried stripping the machine and changing a few bits over from another machine but no luck. If I can id the part maybe I might be able to fix. thanks....
Posted on Nov 01, 2012
  • mike
    mike Jan 02, 2014
    same here. anyone can tell me how to fix or i have to send it back, thanks
It always shows fill up beans but the beans container is full.. how to fix this problem for a Krups Xp9000
somewhere I read that there is a window /sensor that needs cleaned really good so it sees the beans
Jul 19, 2015 | Krups Coffee Makers & Espresso Machines
How do you remove brew unit
I have done XP9000, this may be similar. Remove side cover, operate lever on side of exposed brew unit and pull brew unit out with the handle. You can only do this when machine is in normal 'at rest' position. Unit will not come out in any other position.
May 06, 2015 | Krups Ea9000 Barista Espresso Machine
Xp9000 does not in form me that it has run out of beans, any help please , thanks
They only know that the beans is empty when it comes to compressing the grounds into a puck just before brewing. If the brew unit has nothing in the chamber to compress then it assumes you are out of beans.. Remove and thoroughly clean the brew unit and make sure grounds are exiting the grinder when the grinder is running.
Oct 19, 2014 | Krups Super Automatic XP 9000 Espresso...
How to remove safely plastic casing on Krups XP9000
Remove book holder at back by pulling it off by hand. Undo the screws visible at the back cover, there's about 4 or 5 or so there. Unclip that centre back panel now screws are out. Remove clear beans cover, remove water tank, lift up the lid to drop grounds direct to brew chamber. Both side lids in open position. Now firmly grip the top cover and try and slide it directly backwards. If it is stuck a firm thump against the front side of the cavity you removed the water tank from while still pulling the top cover backwards will free it up. The sides lift directly upwards to get them off. When replacing the water tank side panel you need the front door open to clear a little spring leg.
Oct 19, 2014 | Krups Coffee Makers & Espresso Machines
The frother doesn't work on my 2nd hand Krups XP2070
The frother usually has a rubber tip. The rubber tip normally has an additional pipe right next to the frother. The pipe's black plastic tip has a very small hole in it. This can get clogged and the frother will not work. Take a pin/needle and unclog this very small hole. The pipe itself can be plugged with milk residue and will need cleaning.
If you take the strainer cup and hold it up to a light, you can see if all the holes are open. If not, this will slow down the brewing process and create a LOT of back pressure which can force the water to flow out through the sides above the strainer cup. Take a needle and open each hole of the strainer cup.
When grinding your own beans, try not to process the coffee too fine or it starts to fit into the holes of the strainer cup. This can also slow down the brewing process. If you grind a batch too fine, you can sometimes get a way with mixing it with a batch of coarse or under-ground beans.
Mar 20, 2014 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
How do you grind the coffee beans
open the brew baSKET LEVER UNTIL IT LOCKS, THEN TURN THE MACHINE ON.
Jul 12, 2009 | Krups KM7000
Krups Super Automatic XP 9000 Espresso Machine Logo
1,025 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
