Question about Craftsman Garden
I have a craftsman 917378480 walk behind mower. It starts up when cold , runs for a minute or two and then quits. Any suggestions?
5 Suggested Answers
  • 127 Answers
SOURCE: Craftsman 5.5 Gold mower will not start
YOUR PROBLEM IS SIMPLE.
FIRST OF ALL THE HOLE IN THE PRIMER BUTTON MUST BE THERE TO POP BACK OUT EACH TIME YOU PRESS IT NOW AS TO THE GAS COMING OUT OF THERE
THE FLOAT IN THE CARB IS STUCK IN THE FILL POSITION AND WILL NOT LIFT ONCE THE BOWL IS FULL TO STOP THE GAS FROM FILLING OR YOU HAVE A PIN HOLE IN THE FLOAT ITSELF.UNDO THE NOT ON THE BOOTM OF THE BOWL WITH THE LAWN MOWER TILTED ON A 45 DEGREE ANGLE SEE IF YOU CAN MOVE THE FLOAT UP AND DOWN IF IT IS FREE MOVING SPRAY THE WHOLE AREA CLEAN WITH CARB CLEANER AND REASSEMBLE TRY TO START ,IF STILL THE SAME PROBLEM YOU WILL NEED TO REBUILD THE CARB AND INSTALL A NEW FLOAT
Posted on Jun 26, 2009
  • 24 Answers
SOURCE: I have a craftsman 6.0 gold walk behind mower with
sounds like diaphram problem. your not getting any fuel. you might be able to buy a kit from napa or sears pretty inexpensive. http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears try this for your manual.
Posted on Jul 08, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
SOURCE: walk behind craftsman lawn mower. starts but shuts off
my craftsman 917378490 left front wheel has stopped pulling.
Right front seems ok. Axle is turning on left front from gearbos.
Posted on Apr 13, 2010
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
How do I check the cut off switch?
If the oil is low, it will not start.
Jul 14, 2014 | Craftsman Garden
Craftsman Snowblower Won't Start
If you did not put gas stabilizer in your fuel tank when you stored your machine the gas will turn into varnish. Try draining the gas and put new gas and try to start it. Good luck
Jan 04, 2014 | Craftsman Garden Tractor Snowblower...
I have a carftsman walk behing mower with an eager1 egine
did you turn the mower upside down then the oil filled up the oil filter take off the filter then it should start it has to breath it takes mor air then fuel to make a engine run
Aug 30, 2009 | Craftsman Garden
Walk behind craftsman lawn mower. starts but shuts off after 15 minutes then will restart after it sits for 10 or 20 minutes
not sure what model but it sounds like it runs hot? make sure the fuel/oil mixture is correct, exhaust is not clogged, sparkplug is in good condition. hope this helps.
Jul 12, 2009 | Garden
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
Garden Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
