Question about Sharp AR-235 Copier
Call for Service error message E1-12
The copier shows the following message on the screen:
Call for Service
E1-12
  • 59 Answers
Hi E1-12 for image processing unit ,
thanks
Posted on May 14, 2010
Testimonial: "I would like to know if there are any codes to press to clear this error, or if it means a bad image processing unit that must be replaced. Thanks for the quick response!"
I have a code E000013-0001 code showing on Canon 6055i copier
Its on the rear bottom right, I believe there is two screws, remove the panel and take out the bottle and empty it. After replacing the waste toner case or removing the waste toner from the case, clear the toner counter in service mode as follows:
To get into service mode, hit additional functions[*] 2&8 follow by additional functions[*] again. [Select [COPIER> Counter> MISC> WST-TNR], press "C" (Clear key) to clear the counter, and turn the power OFF/ON.
You can also change the detection level as follows:
The waste toner detection timing is determined by the total page counts specified in service mode below:
1. Page counts until the warning message is indicated
2. Page counts between the warning message and E013 indication
Field Remedy
Follow the steps below if you want to change these page counts:
In service mode [COPIER> Adjust> MISC> WT-FL-LM], select any number from "0" through "4".
0: 80,000 / 1: 140,000 / 2: 210,000 (default) / 3: 320,000 / 4: 460,000
In service mode [COPIER> Adjust> MISC> WT-ER-LV], select any number from "0" though "3".
0: 1 / 1: 20,000 / 2: 40,000 (default) / 3: 60,000
Apr 24, 2013 | Canon IMAGERUNNER 6570 Copier
My kyocera km-2550 multifunctional copier has started showing a error message "call for service c6000" and a phone number in asterisks. kindly advice on what to do or if there any online help.
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.
In order to reset this code: follow those steps
on the panel press 1087 1087
The screen will change to service mode
on the panel again press 163
now look at the screen and you will see Excute.
Select Excute and press the Start key.
The Machine will rebot or it will asks you to turn it off and on.
After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit.
Oct 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Hi I bought a Lexmark X204N and now it is showing the following error message: error message: 931.01 service no first Hsyncs I am unable to print from this printer at the moment and it is causing a lot...
This error indicates that it cannot communicate with the laser printhead. Please click on the link below and follow the recommended steps. http://bitly.com/o51ckY
If you need further assistance, please contact Lexmark Technical Support Center.
Apr 05, 2011 | Lexmark X342n All-In-One Laser Printer
I keep getting error 50 or error 51 and the screen says unable to print. I have followed the instructions of customer service and cleaned the coding band and checked for paper specs to no avail. I...
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Robb
Sep 24, 2010 | Brother MFC 490cw Color Inkjet...
Error message one brother mfc-5440cn
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
annoying cannot clean message.
Oct 28, 2009 | Brother MFC-5440CN All-In-One InkJet...
Unable to clean,check manual
Oct 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
Konica 7020 copier
35-9 is a low temperature error in the fuser.If the fuser has a problem it will not make a copy period.Sorry. Mrbonz
Jul 20, 2008 | Office Equipment & Supplies
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Dec 04, 2007 | Konica Minolta Di1610 Copier
Sharp AR-235 Copier Logo
215 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
