Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Convergence is OK for a few minutes
After a few minutes it pops way off, but after about 20 minutes it pops right back again. All parts clean and free of dust. Thanks! John
Panasonic PT53TW53G
    President:
  • 3,130 Answers
It sounds like you might have intermittantly bad convergence ic's and/or bad solder connections on the STK ic's but if you resolder them and the same thing has the same issue I can tell you at this point is to go to tvrepairkits.com and order the completeconvergence kit for your model of TV set,
no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.click here please if you wish to repair it yourself and save close to 400.00 bucks
http://www.fixya.com/support/r3342653-convergence_fix
Posted on May 14, 2010
My 2001 hyundai accent keepd dieing when I come to a dtop won't take a jump cant pop the clutch either all lighys inside and out work let it sit for a few minutes it starts right up but then just does it...
first what I would do is, check all your cables.going to.and from your battery, make sure they are clean.and tight then.check the cable going to your starter, again make sure it is clean and tight check to see if you have any codes stored in your computer, almost any auto parts store can do this for you
Dec 05, 2013 | Cars & Trucks
Toshiba TP50G60 Convergence Problem ??
it was on the video output module, check bad resistor near the video output module..
let me know
Aug 07, 2008 | Toshiba TP50G60 50" Rear Projection...
Will not stay powered on
Hello, please check Q710 in high voltage circuit. If you need more info please advice. Arpi
Aug 11, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Pop Ups on Desktop & Laptop. I have a friend who has pop ups off and on and I can't figure it out. I even took my computer over and within 20 minutes I started getting pop ups as well. Once I...
haunted, maybe, or maybe at home you have a firewall enabled in your router and your friend has not. Maybe there's another infected pc on his network that's bombarding you with this ****, can you specify the network setup from A to Z ?
Jun 22, 2011 | E-Machines eMachines Desktop PC
It Starts and runs fine for about 15 minutes then
I think that your right. Sounds like your ignition coil witch is most likely located under the the flywheel cover. I know that on some briggs and stratton engines they are actually under the flywheel, just trace the sparkplug wires to know for sure. When the ignition coil beginns to fail they start slowly (spitting and sputtering) and then they get to the point to where they stop firing after getting heated up and adventually quit all together.
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Wavy picture
It looks like you have a convergence problem here, probably a defective convergence IC.
Mar 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Convergence on mitsubishi WT-46805
Mitsubishi is famous for this. You are going to have to resolder the convergence ICs. Very simple repair if you are just a little tech savy. Do you know how to solder? This is a 99% fix. Take the back cover off (unplug first). You will see a big heatsink on the board (6-8 inchs long) attached to this are 2 convergence ICs. Unscrew the board, flip it over and resolder all the pins to those 2 chips. Done
Feb 11, 2009 | Mitsubishi WT-46805 46" Rear Projection...
I think it what is called convergence
Maybe loose connection on the convergence board around the IC's or amps
Mar 22, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Dec 02, 2007 | Thomson LCDB 03B 27 in. Television
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
