The water line is checked and working, but no ice. Help!
Hi reach up inside the tray where the ice is made and check to see if you feel any ice. If you feel ice the ice maker is bad. If you feel no ice and the tray is empty then your problem is either with the water line being blocked with ice or the inlet valve is bad. Pull the ice maker line out of the valve and blow into it, if you can blow air through the line then the valve is bad. If you can't blow air into the line then it's blocked with ice. Locate the ice blockage and thaw it with a hairdryer. Mike
The ice
maker not working: ---
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
