Question about Canon PIXMA iP3300 InkJet Photo Printer
Cannot communicate with printer. Told to Turn
Cannot communicate with printer. Told to Turn enable bi-directional support on in the printers properties dialogue box. The box is grey!
    Brigadier General:
  • 10,406 Answers
Restart your computer.
Press <DEL> to enter BIOS SETUP.
Find the setup-screen that changes the mode of the printer (PP/"Parallel Port" or EPP/"Extended Parallel Port", or ECP/"Enhanced Port"). Select EPP or ECP.
Then, 'SAVE' the updated BIOS settings,
and exit from BIOS SETUP.
The box will _not_ be "grey".
Posted on May 14, 2010
Why should I turn on enable bi directional printer properties dialog box
If you have a bi directional printer then you can increase the print speed by enabling it in the properties. Most older printers only print in one direction and the return to a home position to print again. Bi directional printers will print in both directions so there is not wasted movement of the print head.
Jul 24, 2013 | Computers & Internet
My computer cannot detect my scanner. Error Code: 0x0070800
The FB320P is a parallel port scanner and is having problems communicating with the computer. Are you connecting it directly to the parallel port on the computer? In that case, you may not have bi-directional communication enabled. Turn off the scanner and the computer and disconnect the data cable from the computer. Turn on the computer and enter the BIOS. (Press Esc, F1, F10, or Del repeatedly after you turn the computer. You should see a screen with the correct key to press; it varies depending on your BIOS and motherboard. If you miss the timing, shut down the computer and try again.) In the BIOS, search for the parallel port settings and see if you can enable bi-directional communication.
Not all parallel ports support bi-directional communication. If you can't enable the feature, you need a different parallel port. Try a PCI slot add-on card; just check the features and check the manual for enabling bi-directional communication.
If you are using a USB to parallel port adapter, get a different one that supports the bi-directional communication.
What OS are you using? There are a few that had ASPI driver issues; a third party app, ForceASPI, may help. See http://www.afterdawn.com/software/cd_dvd/dvd_tools/frcaspi.cfm for information.
I hope this helps. Please add more information about the configuration (cable, OS, etc) for extra ideas to solve the problem.
Sep 16, 2012 | Canon CanoScan FB320P Flatbed Scanner
Trying to print to a dell photo aio printer 964 from my laptop and it keeps telling me "communication not available; the printer cannot communicate with the computer; please turn on enable...
Bidirectional Printing - A means of printing by a computer printer which prints one line from left to right, then the following line from right to left. Such printing is faster than printing in one direction only, as there is no need to wait for the carriage or other imaging mechanism to return to the left margin before starting a line.
how to enable bi-directional printing.here's how:
  1. -click on start
  2. -click on printers and faxes (control panel->printers and faxes)
  3. -right-click on Dell Photo All in One Printer 964 All-In-One icon
  4. - click on properties
  5. -click on ports tab
  6. -down at the bottom there's a small box before bi-directional support
  7. -tick the box to enable it then click apply,ok
  8. -try printing again
note: in vista , printers and faxes is printers.in win 7 ,it's devices and printers.
and properties in win 7 is printer properties
Jun 05, 2011 | Dell Photo 964 All-In-One InkJet Printer
I have a BJC80 printern with a scanner head. My pc is an xp opertins system. It is connect to parallel port but when i try to scan, it sends me back an error message saying there is no communication.
One of two issues may be involved. 1) Make sure you have a bi-directional IEEE-1284 parallel printer cable, 6 feet or less long. 2) Make sure that the parallel port is set to ECP mode (the BIOS is accessed by hitting F1 or F2 during boot on many computer, check your manual.) Try a new cable (just in case the cable has just enough damage to prevent the scanner from getting the full bi-directional communication).
I hope this helps.
(the lack of bi-directional communication only disables the scanner, the printer will still work)
May 08, 2010 | Canon BJC 80 InkJet Printer
Need to enable bi-directional support
Go to printers and devices and right click on the pic of the printer and click on printer properties!allmost sure its under the advanced tab!Good Luck!
Apr 09, 2010 | Canon Pixma iP4500 InkJet Printer
Lexmark 3500-4500, enable bidirection printer
Bi-directional operation is a facility of the BIOS port you might use. it usually refers to a parallel port which can be set in the bios as uni directional or bidirectional so in the bios under PERIPHERAL DEVICES you would set to bi-directional.. so it is not something you can set in the printer settings. when it connects to the port the printer tests to see if it can use bidirectional transfers or not. If it can't it just means its a bit less efficient so will take long to transfer data. A similar error message might be issued for a network/wifi connection if a FIREWALL prevented communications. Or if you had used an OLD driver meant for a different older parallel printer. your printer is too new and should be wifi connected. You may have used a wifi ad-hoc pc-printer direct connection which could be causing the issue. preferred method is always printer-router-pc non ad-hoc using tcp/ip ports. so check your firewall settings http://support.lexmark.com/index?page=content&id=SO3908&locale=en&userlocale=EN_US
Oct 03, 2017 | Office Equipment & Supplies
What it means Enable Bidirectional Communication
To enable bi directional printing:
Open Printers and Faxes in control Panel
Right Click on the Printers Icon
Select PROPERTIES
In the Properties dialog box select the PORTS tab
Near the bottom there is a check box to enable Bi-directional printing
Make sure it is checked
Click OK to exit the dialog box
Feb 17, 2009 | Lexmark X2470 All-In-One InkJet Printer
Can't enable Bi-directional support for Canon MP610
go to cannon website and download new drivers for windows 7. Had the same problem and this fixed it right up
Dec 11, 2008 | Canon MP610 Photo All-In-One Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
495 people viewed this question
old marine
old marine
