Question about Lands Phones
How to set time & date on phone
Nortel Maestro L.N. 20 caller I.D phone
  • nee-nee puts Mar 30, 2008
    don't know how to set time & date
If you subscribe to Caller Display services, the first incoming call will set your phone's date and time automatically. Otherwise, here is how you do it.
1. press Options 2. Press * three times The display shows "Enter time/date?"
You may set both time and date or you may set either of them separately
TO SET BOTH 1. Press # when the display shows "*=Next #=Enter" 2. Wait for each prompt. You will be asked to enter: - the time - am or pm - SAVE - the month - the day, and  - SAVE (Enter the hour, day, and month as two-digit numbers. For example, enter 02:15 for 2:15, 05 for May and 08 for the 8th of the month.)
TO SET ONLY THE DATE 1. Press # when the display shows "*=Next #=Enter" 2. Press * when the time appears 3. Enter the month and day when prompted. 4. Press SAVE
I have a question for you: Can you give me the specs of the AC adapter for this phone (usually written on the adapter)? 1. What is the OUTPUT in volts (V)? 2. What is the OUTPUT in milliamperes (mA)?
3. What is the polarity (i.e. is the + sign in the center of the jack or on the exterior)?
(The wall plug transformer has a diagram depicting two circles with the inner circle representing the center conductor. A line coming from the inner circle will show a minus (-) or a plus(+) symbol to let you know the polarity of the center conductor.)
Thanks!
Posted on Dec 01, 2008
If you press options and * two times you can change the language to english or french.
Posted on Aug 06, 2009
Is there a way to setup caller id on a Nortel system that show when the phone rings
In system programming, you can select whether the display is the name, number, or line.
F**CONFIG
Terminals&Sets
enter extension #
skip Line Access, Capabilities, Name, User Preferences
Telco Features
skip Feature Assign
at 1StDisplay use CHANGE softkey to toggle to NAME.
Mar 26, 2014 | Nortel Lands Phones
Change date and time on nortel t7616e
That is a system setting... Depending on what KSU common equipment you have. Feature **TIME might do it, systems with Caller ID Cavan set the clock on an incoming call.
Jan 15, 2014 | NorStar T7316E Corded Phone
How do I set the date and time on the answering machine of my my Panasonic cordless phone model kxtg5632. I have a lot of power outages and every time I have one the date and time falls off the answering...
5 8 GHz Expandable Digital Cordless Answering System with Two Handsets
Possible issue if you have Caller ID:
Why does the date and time change automatically after I have programmed the date and time on my phone?
If you are subscribed to Caller ID from your phone company, the unit's date and time setting will be automatically adjusted when caller information is received. If you do not wish for this feature to work, press [MENU] [#] [2] [2] [6] on the handset, then press [0] to select "Manual" and press [SAVE]
ftp://ftp.panasonic.com/telephone/om/kx-tg5631_en_om.pdf
Page 21 - setting date and time in manual at link above.
Feb 16, 2018 | Panasonic KX-TG5632M Twin Cordless Phone
After installing new batteries I have lost my time and date on the window display
The date and time is supplied with the caller ID information from your phone service provider. When you get a call, the date and time will be set. (If you don't have caller ID, there's no way to set the date and time otherwise. I've always wondered who came up with such a silly design.)
Jan 30, 2011 | GE 29385GE1 Corded Phone
How to set the time on Caller ID
Panasonic KX-TG2740 user manual is available in the following link,
http://www.fixya.com/support/p123254-panasonic_kx_tg2740_cordless_phone/manual-7363#
Page 20 contains the details about setting the date and time.
Page 40 contains the details for the caller ids service.
Good luck :)
Jun 07, 2010 | Panasonic KX-TG2740 Cordless Phone
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Caller ID date and time doesn't show up on cordless phones
Here is a link to the manual for the 756 series of Uniden phones.
http://www.uniden.com/pdf/DCT756om.pdf
You should just have to set the caller ID time and date. Hope this helps.
Mar 29, 2009 | Uniden DCT756-3 Phone
Time and date
Press feature ** "time" to set the time
And Feature ** "date" for the date.
Jan 02, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel M7310
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Oct 25, 2007 | Lands Phones
Lands Phones Logo
486 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
