Question about Lenovo ThinkPad R61 Notebook
Getting beep sound when i start my laptop R61, cannot start
  • ikkenom May 14, 2010
    Most computers do beep _ONCE_ to indicate that the POST (Power On Self Test) has _SUCCESSFULLY_ completed, and that the computer is about to start to "boot" from your disk-drive. Remove any CD-disks and USB-devices and 3.5" diskettes.
    Novelist:
  • 162 Answers
Hi. I think the problem on your machine is the RAMS if you here the beeping sound. I would suggest that you remove the memory and clean the contact points with an eraser but make sure that you remove all the receduces and also make sure that when you plug them back you should double check if they are properly seated. If you still having the same issue after doing the troubleshooting step then try a known good memory so that you could make sure that the problem is not with the memories you have.
Posted on Jun 03, 2010
  • Jewell VIlladiego Nov 19, 2012
    hi there I hope you could help me on my problem. my laptop keeps beeping during system start. I was worried what the problem of it, could it be the hard drive? my laptop model is lenovo ideapad y560. thanks! hope you help me..
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
May 07, 2014 | Lenovo ThinkPad R61 Notebook
Lenovo r61 startup repair is not working
What were you doing before it happened?
Apr 15, 2014 | Lenovo ThinkPad R61 Notebook
Lenovo r61 screen
Open the panel on the back and remove the ram. Boot the computer. If the boot code changes then it's probably bad ram. If it's the samew beep code then probably a bad motherboard
Jan 20, 2014 | Lenovo Computers & Internet
I am hearing 4 beeps 4 times during power on, but system does not start- IBM thinkpad lenovo R 61
Usually this means that the memory is defective or has been removed or popped loose in its sockets. Try to reseat the memory DIMMs or replace them.
Sep 24, 2013 | Lenovo ThinkPad R61 Notebook
Horizontal lines in lenovo r61
This is a indicator of defective LCD screen, the only option is replace the laptop monitor, go to www.ebay.com Type make and model of laptop, refine search to screen to get an idea of pricing.
Jul 03, 2012 | Lenovo ThinkPad R61 PC Notebook
IBM Lenovo Thinkpad R61 gets 1 long & 2 short beeps on startup
Try this:
Open two RAMs, clean them properly and connect only one RAM then try. If nothing changes, then remove the RAM and insert the other one. And try again.
If this fails too, then there is a good chance that you have motherboard related problem
Nov 23, 2008 | IBM ThinkPad T30 2366 Notebook
Lenovo R61 won't get to login
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Jul 03, 2008 | Lenovo R61 T7300 Notebook
Lenovo Thinkpad R61 7732 Hissing Sound
hi
try running a test on youe battery frim control panel
or
try and boot the system in safemode and check if it works there if Yes then its an OS issue if no the boot in bios and reset the setting to default and try agian
Jun 16, 2008 | Computers & Internet
Lenovo ThinkPad R61 Notebook Logo
278 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
