Question about Panasonic KX-T7633 Corded Phone
Time and date
How do i change the time and date on our phone system
how to set date & time
  • Anonymous Mar 30, 2014
    set date time
  • 3 Answers
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Posted on May 07, 2008
    New Friend:
  • 136 Answers
Which kind of phone
Posted on Mar 30, 2008
SOURCE:
SOURCE: Setting Time and Date on phones
Just got this phone. It is indeed day/month/year. European style. NOT what we want for a phone in the states. Really annoyed with the fact there is not an option. Might be returning it.
Posted on Dec 26, 2007
SOURCE: time and date
Press feature ** "time" to set the time
And Feature ** "date" for the date.
Posted on Jan 02, 2008
SOURCE: Reprogramming the date for daylights savings time.
From extension 10 or 11
feature 00
left intercom
left intercom
#126
press the 2 button
feature 00
That will disable it.
Posted on Jun 03, 2008
  • 45 Answers
SOURCE: We have a DKT3020 phone system. How do you set
You can go to any display phone:
For the date
1. press intercom
2. dial #651
3. enter yymmdd example ~ 091005
4. press the # key.
5. hang up
For the time
1. press intercom
2. dial #652
3. enter HHMMSS example ~ 170800 in military time.
4. press the # key.
5. hang up
Posted on Oct 05, 2009
Phonesmith
  • 113 Answers
SOURCE: changing the time settings
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.:
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Posted on Mar 29, 2010
Testimonial: "The instructions were very clear and easy to understand.Thankyou very much."
Lg venice time and date
go to system settings and select date and time uncheck the autosync with network to set your own time and date
May 30, 2014 | Boost Mobile Lg Venice No-contract Mobile...
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
The time and date are programmed through system programming. A 4015 phone cannot do this programming. A 4150 phone setup as a subattendant phone with the "attendant setup time/date" class of service option enabled for the 4150's class of service can change the system time and date. This is accessed through the LCD touch screen keys of the 4150. Scroll through the options in the screen until you find set time /date.
Also an attendant console with the "attendant setup time/date" class of service option enabled for its class of service can change the time and date. Press the function button then choose attendant function.
Choose set time. Enter the time in four digits as in 0800 for 8:00. Choose PM if needed. Choose set.
Choose exit to finish.
Dec 13, 2010 | Mitel Superset 4015 Corded Phone
I need the directions to set the time and date on Partner 18D phones and how to set up extentions
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
To change the date enter #101
the display will say system date and the current programmed date
enter in the new date in MMDDYY format
press feature "00" to logout
As far as setting up the extensions, I'm going to need a little more specific info to help.
Aug 26, 2010 | Lucent PARTNER18 Corded Phone
HOW DO I SET THE TME AND DATE ON PHONE
enter in "#103"
enter the new time in 24 hour format to change the date enter #101 the display will say "system date" and the current data enter in the date in MMDDYY format
Aug 15, 2010 | AT&T Lucent MLS-12D Phone
How do you change the time on the phones. Since Daylight Savings time My clock is off by an hour
How do I change the Time and Date on a Merlin Legend system?
To change either the Date or the Time on the Legend system, you must program it from the main System Programming console (MLX-20L). This will change the Time or Date on all the display phones throughout the system, except the ATL (Analog) display sets. These phones must be programmed on each individual set.
How to change the Date in the Legend system:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit.
  4. Press System.
  5. Press Date.
  6. Enter date in following format: mmddyy (where MM is the month, DD is the day, and YY is the year).
  7. Press Enter.
  8. Press Exit.
  9. Press Home to exit programming mode.
How to change the Time in the Legend system:
  1. Press Menu.
  3. Press Exit
  4. Press System.
  5. Press Time.
  6. Enter the time in military/24 hour format: HH:MM (where HH is the hour, 01-24, and MM is minutes, 00-60).
  7. Press Enter.
  8. Press Exit
Nov 04, 2009 | Lucent Merlin Legend MLX-20L Phone
Change the time on the clock
This must be done on the phone system as the administrator. For 6.0 software go to System-wide settings, set date and time, and you can set it there. For 5.0 and older, go to Tab to it, System configuration, system settings, date and time. Once the time has been set on the phone system the date is updated instantly on the phones (even before your browser finished loading the next page).
Sep 23, 2009 | 3Com NBX 3101
HOW DO YOU SET THE DATE AND TIME?
It should be in 'settings' on your cell phone menu. Search around your phone. It could also be in 'organizer'. On my old one, it was in 'organizer', and once I went there, there was a 'set date and time' button. Here is the answer from the Vtech website: "Make sure the answering system is on. Press [Time/Set]. The system will announce the current clock setting, then announce "to set date and time, Press Time/Set". Press [Time/Set]. Press [Change] until the system announces the correct day, then press [Time/Set]. Press [Change] until the system announces the correct hour, then press [Time/Set]. Press [Change] until lthe system announces the correct minutes, then press [Time/set]. The system announces the current clock setting. Note: You can press and hold [Change] to advance the mninutes in increments of ten. "
Jun 06, 2009 | Vtech Lands Phones
To set time and date on toshiba
What Toshiba system do you have?
CTX Programming
--(time set)ctx-intercom #652 HH MM SEcs #
--(date change)-intercom #651 YY MM DD #
DK Programming
From Reception phone only
--(time set)DK- intercom #652 HH mm SECs redial
--(date Change)- intercom #651 yy mm dd redial
Jan 10, 2009 | Toshiba DKT2010SD Phone
Set time and date
hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
then **8463
password is 23646
follow prompts :)
hit the hang up (phone with arrow underneath) when fone.
Jan 22, 2008 | Lands Phones
Panasonic KX-T7633 Corded Phone Logo
1,040 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
