Question about Gateway PLSM46TV 46 in. Television
I had a flash on my tv and now it doesn't work but there is a blinking hourglass now blinking on it. What does that mean?It is a 46" gateway flat screen.
  • Gateway Master
  • 8,457 Answers
U mean now,u turn on the tv,u just a flash of picture only few sec. but u still have sound?This problems mean,u have a dead board call the LCD inverter board.Take ur tv aparts,replaced this LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 14, 2010
Sony KDL-46XBR4 46 in. LCD flashing light. Light flashes red 8 times pauses
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC. Try this link too.
Dec 20, 2013 | Sony KDL-46XBR4 46 in. LCD Television
After replacing all capacitors on the power supply board,Tv still doesn't come on
if only a blinking indicator at the tv panel that was mean has an error detected by the main board. if no any power indicator then you have been already replaced bulging capacitors but still won't turn on. at this time you will need to have voltage checking using a digital tester, if their is an output voltages at the power supply board.
Jan 18, 2013 | Samsung LN46A530 46 in. LCD HDTV
Aquos lc40le821e. LED is blinking constantly at a rate of 1 blink / 2 secs. Cant get the tv on. Any ideas? Thanks.
Sharp LCD tv tend to have trouble with power LED light and OPC light flashes together?That what u having?Yes,this tv is having trouble with it tv Tuner signal board itself.This tv is still useable.By pushing the power button again and wait for awhile than the backlight will come on and work,Sometime Power and OPC LED lights flashes quit awhile.Just have to push power button and wait have to do this 3 or 4 times,before tv backlight to come to work.I have a Sharp Aquo my self 46' do this most of the times.
Jan 01, 2011 | Sharp Televison & Video
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Have a red blinking light on tv tv does not turn on
Normally one red blinking power indicator means your television needs a main board and or a power supply. The television would need to be evaluated and if you need a power supply only perhaps the service provider can rebuild it for less than $200. If the television needs a main board perhaps Sharp will work with you if you have an estimate. If you really have an aquos television 46 inches or greater you can get assistance at 877-332-7867
Aug 19, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The TV does not work and the red and green light flash together
This could mean your lamp is bad or your lamp timer is max and needs to be reset. Check your manual to see what the blinking lights mean.
Jan 16, 2010 | Toshiba 46HM95 46" HDTV
Our tv has a flashing power button. We cannot get it to stop flashing, and we cannot see anything on the screen.
blink--blink---blink or blink blink-----blink blink---blink blink?or blink with the OPC?
Mar 28, 2009 | Sharp LC46SB54U 46 in. LCD TV
Won't turn on
Flashing or blinkings diagnostic code meaning;
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Bad solder or loose, crack ,cold solder connections joint,you must reworks or resolder joint of the "D" board so it will works normal again.
Hopes it may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony 46"lcd tv x series
Can you please post the exact model number from the back. The 10 blinks is an indicator of the probelm circuit, but is specific to the model number. I can provide more details once I have the model.
Thanks,
Dan
Mar 19, 2008 | Televison & Video
Open Questions:
Gateway PLSM46TV 46 in. Television Logo
144 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
