Question about Maytag PYE2300AY Electric Dryer
Power on the dryer. checked timer switch. pushed button on timer and power is going through switch but nothing is happening
  • Maytag Master
  • 19,396 Answers
Hi.
You will probably need to replace the thermal fuse or the high limit kit.
The model listed has a three fuses high limit pieces. Here the part:
High Limit Kit
With the kit you get an high limit (Limit: 258) the gas high limit (Limit: 240) and the gas and electric high limit thermal fuse (Limit: 300).
The high limit fuses often blow at once when there is overheating.
To replace the high limit parts:
  • Unplug dryer from power outlet
  • Lift dryer top from front cover and let it rest on the hinges.
  • Check the rear top side behind the drum and locate the
  • thermal fuse
  • Disconnect white and red wires to high limit and thermal fuse.
  • Replace the parts
Before replacement fuse and high limit can be tested reading Ohms with a multimeter set on impedance at Rx1. If the parts are good, they must read zero or low impedance. When they blow, they return no continuity.
To get the part you can also enter the model number on the website linked below. ensure that you are entering the right model number. I posted parts for the model in title.
Where do I find parts and diagrams?
Regards.
Ginko.
Regards
Posted on May 14, 2010
  • jmann03 May 14, 2010
    how do you lift up the top of the dryer
2 Suggested Answers
  • 8 Answers
SOURCE: Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Posted on Nov 29, 2008
Mayfield dryer model pyet244ayw, has power nothing
CHECK THERMAL SHUT OFF, DOOR SWITCH AND PUSH START BUTTON
Sep 27, 2014 | Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Maytag Dryer
are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
drcool
Sep 17, 2008 | Dryers
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Mar 24, 2008 | Estate TEDX640JQ Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
