Question about Kitchen Ranges
Maytag 800 oven will not turn off
When power is interrupted the oven is off. When the power is restored the oven is on. Clock is normal showing time.
  • Kitchen Ranges Master
  • 43,501 Answers
Here is a tip that will help you with that overheating oven...
ElectricMaytag 800 oven will not turn off - 2_bing.gif Oven Problem Oven will not shut off
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Posted on May 15, 2010
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
You are in Jewish Sabbath Mode, it is 'Sab'
Search Results Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab". To disable the Sabbath mode push and hold the Clock pad for 3 seconds.Nov 10, 2007
Maytag Oven WEIRD Error Code 5ab - Appliance Repair Forum
forum.appliancepartspros.com/oven.../2348-maytag-oven-weird-error-code-5ab.html Feedback
About this result
Will you tell me what error code 5A6 means on Maytag MGR6875ADQ ...
https://www.shopyourway.com/questions/1098960 Nov 24, 2010 - As indicated in the previous response, the 5A6 indicates that the range is in the Sabbath mode (SAb). The image below shows the information on this mode for your range. Press the CLOCK button and hold it for 3 deliberate seconds to cancel this Sabbath mode. The control should then work normally. what does the f-2 error code on my maytag oven mean?
26 Jun 2010
What does the SAB error code mean on my Maytag ...
1 answer
1 Jan 2010
How do I cancel the Sabbath mode on my Maytag range?
30 Dec 2008
What does an SA6 (or 5A6) error code mean on my ...
1 answer
13 Nov 2008
More results from www.shopyourway.com
Maytag Oven SAb error code - YouTube
? 0:54
https://www.youtube.com/watch?v=XUP1BOzqPUo Jan 1, 2014 - Uploaded by Life With Christ
The SAb error code will freeze your oven functionality and you will not be able to cook or program the oven ... Oven Repair including Ranges and Cooktops
Mar 12, 2018 | Kitchen Ranges
Replaced blown broiler element on Maytag oven mer5765qaq. Display did not come back on . stove top still works.
Good afternoon Schurtzfamil.
For a number of appliances, there can be recurring hiccups with displays after power is interrupted. Hopefully you unplugged the oven, or opened the breaker when you did the element replacement.
The manual can be downloaded here (
http://www.maytag.com/digitalassets/MER5765QAQ/Use%20and%20Care_EN.pdf ) There are a number of troubleshooting tips, including things like 'it's in Sabbath Mode, which is why the display isn't responding' that might help.
Lame as it may sound, the answer in many cases with the confused, power-interrupted display is to go back to the breaker, turn it off for a couple of minutes, then turn it back on. That will give it time for completely power down, and hopefully start normally this time. Hoping this helps! Good Luck!
Nov 18, 2015 | Maytag Kitchen Ranges
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Microwave does not work at all. Shows "PF" in display.
"PF" on the display is an indication that your oven experienced a power interruption. Normally, the error code can be cleared by pressing the CLEAR/OFF button. You may have to reset the time. This is accomplished by pressing the CLOCK button, entering the time on the keypad, then pressing CLOCK again. If this does not clear your problem, please let me know. I hope this helps you.
Jul 26, 2011 | Hotpoint RVM1435 Microwave Oven
APPEAR THE LETTERS PF IN THECLOCK CONTROL
usually, just reset clock..it stands for power failure..if power goes out. they all do this...
Feb 16, 2011 | Ovens
Power Interruption
power interuoption is a power cut / power went off it needs resetting your tech should be able to do this
Jan 21, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Oct 06, 2008 | Maytag MER6772 Gemini Electric Kitchen...
DISPLAY SHOWS "off" WHEN CLOCK IS SELECTED
try to reset the time of day on the clock let me know if that works but dont rate me till were done please
Jan 11, 2008 | Maytag MER5770 Electric Kitchen Range
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Kitchen Ranges Logo
69 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
