Question about Watches
Stopped Pocket Watch
I have the Style #7973T pocket watch. For several days, the timekeeping was eratic, and then it just stopped working. What do I do? Trying to reset it it does nothing. There is no discernable movement.
  • 714 Answers
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on May 14, 2010
Find a third wheel for a rolex pocket watch
Rolex Watch 1530 Part 7831 Third Wheel 60 Teeth Open ' eBay
https://www.ebay.com > ... > Parts, Tools & Guides > Parts > Other Watch Parts
Find great deals for Rolex Watch 1530 Part 7831 Third Wheel 60 Teeth Open. Shop with confidence on eBay!
Rolex Watch Parts - Cal 1210 1215 1225 1220 Third Wheel Part 7507 ...
https://www.ebay.com > ... > Parts, Tools & Guides > Parts > Other Watch Parts Find great deals for Rolex Watch Parts - Cal 1210 1215 1225 1220 Third Wheel Part 7507. Shop with confidence on eBay!
Rolex third wheel in Watches, Parts & Accessories ' eBay
https://www.ebay.ie/csc/Watches-Parts.../14324/i.html?_...Rolex...third+wheel 138 items - Vintage ROLEX Watch Caliber 1300.1 x 3rd Third Wheel Used. ..... ROLEX BLACK DIAL ANTIQUE SWISS POCKET WATCH - SOLID GOLD 9ct GOLD ...
Third Wheel for Rolex 1400 - Watch Material
www.watchmaterial.com/third-wheel-for-rolex-1400/ Product Description. Third wheel to Fit Rolex 1400. Generic Third Wheel; Part Number:1400-2918; Swiss Made. Fits Caliber 1400 1401 ...
third wheel for rolex pocket watch Google Search
Nov 22, 2017 | Rolex Watches
Do new James Michael pocket watches come with a battery?
Yes, if it is of the battery type
Movement Type
The movement, or inner workings, of a watch are what make up the main timekeeping mechanism. This mechanism measures the passage of time and displays the current time and other information including date, day and month. These movements can be entirely mechanical, entirely electronic or a combination of the two.
Mechanical movements, such as hand wound or automatic watches require winding in order to run. An automatic watch uses the force of gravity to constantly wind itself. Automatic watches have a greater consistency of power and therefore can be more accurate.
An electronic watch employs the use of a tiny quartz crystal that vibrates in the presence of electricity. This type of watch is powered by a battery and their time is regulated by the tiny quartz crystal. This is why most electronic watches are also called quartz watches. Solar powered watches convert energy from light into electricity which is then stored in a rechargeable battery. These watches do not need to have the battery replaced as long as they are regularly exposed to a fairly strong light source.
Kinetic powered watches use a combination of mechanical and electronic elements. Usually a weight rotates with the motion of the wearer?s arm which turns a generator to supply power. It is similar to an automatic watch except that electrical power is generated by the mechanical motion.
Men James Michael Pocket Watch
Jun 19, 2016 | Pocket Watches Watches
Just bought a Longine watch L4.309.5.57 automatic, can i use it during sports e.g. Aerobics class and cycling?
I had a similar problem. I had no trouble with ordinary mechanical watches but when lcd electronic watches hit the market I tried a change and bought one which was replaced several times while all my friends had no bother at all.
These days I rarely wear a watch because mostly I no longer care what time it is and my phone has the time on it.
Longines watches are a reasonable quality but an automatic watch is really only suitable for normal everyday activity and such things as aerobics is likely to severely shorten the life of the mechanism. The original "activity" watch was the Swiss incabloc movement but the people who could afford to buy such a watch would not dream of wearing it while performing vigorous physical activity.
I imagine the only watch that would have a chance of standing up to sustained punishment would be a quality digital watch.
A fob or pocket watch would be a sensible alternative. There have been a wide variety of sports fob watches produced, many of them combining timepieces with stopwatch and timer functions.
I hope this helps.
Apr 12, 2016 | Watches
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 | Watches
Why would this watch loose time and have to be reset???..........repeatedly.
I had the same problem sometime ago but with a fossil. I had the battery replaced several times in the matter of a couple of months. It seemed to have happened during the very cold months. I also found that I put my watch in the same pocket I put my Iphone in too. I'm not sure if there was a relevance but after I stopped, the watch seemed to fix itself.
Jan 30, 2011 | Pulsar PXX006 Wrist Watch
Watch is fully wind up but doesn't run?
Several solutions:
Needs cleaning is the best possible reason.
Broken balance due to being dropped is second.
r/
David
Dec 29, 2009 | Sterling J3E Hamilton Antique Pocket Watch
Dont know how to open the case of my jules jirgensen pocket watch
Its like a clasp just use a knife an open it at back case you can groove where you placed the knife tip.
Hope it may helps:
Jun 21, 2009 | Jules Jurgensen 7381 Pocket Watch
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
Mar 19, 2009 | Colibri Mechanical Collection Pocket...
I just bought a Mondaine travel alarm pocket watch. Instructions say the crown has 3 positions. 1> Home normal for a quartz watch. 2> Pull out 1/2 way to set alarm. 3> Pull out all way to set time. My...
It seems like your watch has a little short stem and that's why it has only 2 positions. This does not affect battery in any way, nor the timekeeping.
The only downside of this is that you can accidentaly reset alarm time without knowing it as your watch crown is in permanent 1/2 way position.
If you are happy with that - keep your watch.
Dec 12, 2008 | Watches
I have a Thomas Kinkade "The Light of Freedom" Pocket Watch, an it stopped working, is there a way to wind it up.
good after noon ! i tink your watch is need of general cleaning ! thank you !
Aug 25, 2008 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
