Question about Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
Lights won't come on
My husband replaced a broken landscaping light yesterday and now none of the lights will come on. We tried switching them on manually, but nothing happens. Now when you set the lever to "ON", it trips the main circuit breaker. Any idea what is going on?
    Guru:
  • 351 Answers
If the breaker is tripping, then there is a short in the circuit. The two wires in your lighting circuit are touching somewhere. Could be at the broken light, or below it in the ground. You will likely have to pull that stake or dig around it carefully to see what is going on, When the light was broken, the wire may have gotten damaged also.
Please vote !!
Posted on May 14, 2010
Testimonial: "Thank you very much for your answer. I will have him dig it up and am sure that's what is going on because there was nothing wrong with the lighting until Mr. Fix-It got to work on replacing the whole light!!"
Brake lights won't work on 93 Subaru impreza. Fuse ok, bulbs ok. Brake light switch replaced 1 yr ago
Mr. Williams since you tried with fuse,bulbs and brake light switch with no success,why you do not try to check your circuit by using a tester and see whether you have any broken wire or bad earth?
Aug 16, 2012 | 1993 Subaru Impreza
Passenger window won't go up or down
open the door interior light will be on put the vehicle ignition in run postion dash lights will be on operate the window switch up and down look at dome light if it is dimming a little when operating switch window motor is no good if not remove the switch and check power at switch if none the boot between the body and door has a broken wire
Aug 09, 2012 | 2000 Plymouth Voyager
Why lights won't turn off after a lightning storm last night?
The light switch is defective replacing the switch should solve the issue.
Aug 09, 2012 | Televison & Video
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
May 08, 2012 | Epic 450 Mx Treadmill
I replaced all rear bulbs and i still have no lights when i hit the brakes
If they work when the turn signals or the hazards are on then you need to replace the brake light switch on the brake pedal bracket.If the lights don,t work on hazards but do with the turn signals,then you have a fuse blown.If none of the above work then you need to check the wiring under the truck box for a bad plug in connection,corrosion or broken wires.
Dec 23, 2009 | Chevrolet 1500 Cars & Trucks
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
My brake lights wont come on on my 2003 chevy impala
Some cars have two brake switches under the dash. Try manually pushing the button on the switch while someone looks at the brake lights. It may just need adjusted. Good luck. Please rate me so I know how I'm doing. Thanks.
Dec 30, 2008 | 2003 Chevrolet Impala
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
319 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
