Question about Dryers
I have a 15 year old Asko dryer. The dryer over heats and shuts off. It will start again after cooling and the reset switch is pushed. I've checked the exhaust ducts for clearence and lint filter.I suspect it might be the high limit thermostat is faulty.
  • Dryers Master
  • 2,605 Answers
Hello and welcome to Fixya,
The problem you`re having ( based on your description, checked exhaust/vent duct`s...hi limit tripping...suspect it faulty ) can be provoked by several factors with dryers, but specifically when it comes to asko in this case.
I`ll try to explain the most common and therefore most likely cause or causes following a couple of questions to clarify where you are in the diagnosis process and what you`ve tried.
First...when you reply can you specify the actual model you have, i.e. TD73, T700, etc. ( Likely the TD73 series based on it`s age, but better sure then guessing ).
Since you`ve stated you checked the vents and lint screen, I`ll ask this. Have you tried running a cycle with the exhaust to the outside disconnected ?
If not try it and see what happens, does it still trip the hi-limit ?
If no it doesn`t trip, then you have a venting problem/air-flo restriction somewhere between the dryer and outside.
If yes it`s either a heating element ( asko original part #8063808 ) or blower wheel/impeller ( asko original part #8055200 ).
Both heater & impeller can also be completely clogged with lint causing the hi-limt to trip as opposed to being outright faulty.
Let me know how this goes and I can assist you further in guiding you to access and inspect the heater and impeller based on the answer`s you post back...if you think you`re capable or you may decide to just phone a technician.
In the event you phone a tech. I`ll add this, make certain the tech. is from an authorized asko service provider or potentially you can spend a lot of money in uneccessary repairs and parts.
Good luck.
macmarkus :)
Posted on May 15, 2010
  • Dryers Master
  • 3,740 Answers
Remove the lint filter and wash it with white wine vinegar and a brush (Old tooth brush or dish scrubber). Then wash it with soap and water. Lint filters over time collect the fabric softener fabric sheets or the liquid used in the washer particulate and can appear clean but actually be completely clogged.
Also look deep into the lint filter passages for signs of lint build up. Use a crevice tool and a folded metal coat hanger to remove the old lint. Then go outside and clear the through the wall vent flapper assy on both sides of the metal flapper.
What your describing it poor air flow. The high limit thermostat is working fine as it is shutting down the dryer when it gets hot. You really do have an air flow problem.
The last thing that can cause this is the blower wheel assy that is attached to the motor. If the venter hub has failed or is loose it will not turn fast enough to produce the proper airflow.
If after all ove the above cleaning the problem persists, disconnected the ducting from the back of the dryer and see if it runs normally. If it does then the problem is in the ducting external to the dryer.
So in summation... you either still have clogged ducting / lint filter or.... the blower wheel has failed.
Thanks for using FixYa.
Kelly
Posted on May 14, 2010
  • Kelly
    Kelly May 16, 2010
    Error correction
    For some reason my statement here:
    the word "venter" appears... it should say "Blower Wheel Hub"
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
My dryer shuts off in the middle of a load, I have to hit the reset and it will start, and work or a week or so, then it happens again.
Check to make sure that your dryer vent is completely clear- I don't remember what kind of safety Asko uses, but it could be shutting off because the heat isn't able to escape quickly enough. Run it with no heat and check and make sure that where the vent exits the building there is strong airflow.
Feb 10, 2010 | Asko Dryers
Asko 24 el dryer does not run,no indicator light,Mod 10776110,LMBent
Check the house electrical panel for tripped dryer breaker pair. Push off, then on to reset. If breakers trip again, you have a short circuit within the dryer case--usually the heating element(s).
Aug 07, 2009 | Asko T701 Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
May 07, 2009 | GE DVL223EBWW Electric Dryer
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Power it off and on, again
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
Asko T701 Dryer - Dryer Start Button
This would have to be your door latch, in my opinion. The door simply is not holding in the button.
Dec 07, 2008 | Asko T701 Electric Dryer
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Asko t760 display panel
My Asko T761 had the same problem, power button lights up but the LCD panel if off. This is not the fuse becuase I replaced with "new fuse replacement kit" provide by Asko but this did not solve my problem. All I needed to do was press the "reset button".
Feb 08, 2008 | Asko T761 Electric Dryer
Dryers Logo
217 people viewed this question
Top Dryers Experts
