Question about Apple iPod nano 2nd Generation MP3 Player
Ipod nano itunes isn't reading my ipod nano but the usb cable works perfect and so does the nano.
  • Apple Master
  • 13,434 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Good luck.
Posted on Mar 30, 2008
SOURCE:
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Jul 25, 2013 | Apple iPod Audio Players & Recorders
Unlock
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
Jul 24, 2013 | Apple iPod nano
What is wrong with my ipod ao 5th generation
Flip the iPod Nano's "Hold" switch to "OFF."
The iPod Nano cannot be turn on if the switch is set to "ON."
Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF."
Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds.
The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again.
Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes.
Then, try to turn the Nano on.
Update the iPod Nano's software.
Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes.
Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes.
Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
hope this helps
Sep 23, 2012 | Audio Players & Recorders
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
Enter code i pod \
Hi
Things You'll Need
Dec 30, 2011 | Apple iPod nano
Forgot my code to unlick my ipod
Hi friend, Don't worry.. It is easy to solve your problem. Just follow these steps..
  1. Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC. if you don't have itunes software, get it from here.
  • Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
  • Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
  • Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code
If you still unable to solve the issue, click here to know more information
Hope it works.. Don't forget to rate me please..
All the best.. :)
Jan 29, 2011 | Apple iPod nano
Nano can't be found on computer or home pc the window on nano shows needs connection even though it is connected
1. Try another USB cord or USB cable. 2. Restrart your computer for a try.
3. Reset or restore your iPod for a try, this way can fix many general iPod problems. If you don't know how to do that, you may refer to this iPod tips
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
4. Download and install the latest version fo iTunes for a try.
5. You may try this iPod transfer, it's a nice iTunes alternative that can help you upload music and video to iPod, I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
If you have any other questions, feel free to email me.
Dec 26, 2009 | Apple iPod nano
My ipod ask for a sercurity code whats that i dnt know wat it is its a nano how can i get code
  2. Step 2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
  3. Step 3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
  4. Step 4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
this should help
Sep 25, 2009 | Apple iPod nano
Ipod not recognized by computer or itunes
I struggled with this issue for a while and finally found a post that helped me. Hold menu and the center buttons until the iPod turns off. Then, immediately hold the left and center buttons to pull up the iPod diagnostic menu. Scroll down to the option "Reset" and select it. My iPod was finally recognized by iTunes. Good luck :)
Nov 20, 2007 | Apple iPod nano
How can I use iTunes to put photos on iPod nano?
"You can easily copy images from your computer to the iPod nano using photo sync in iTunes. Please note that you cannot import photos into iPod nano directly from a digital camera or media reader. If you connect an Apple iPod Camera Connector or Belkin Media Reader for iPod w/Dock Connector to iPod nano, you'll get a message on your iPod screen that says, ""The currently attached accessory is not supported by this iPod."" If you connect a Belkin Digital Camera Link for iPod w/ Dock Connector to iPod nano, you'll see a ""Do not disconnect"" message briefly, then the main iPod menu appears. For information on other iPod accessories that don't work with iPod nano, Some accessories that work with other iPod models won't work with iPod nano. Here are some items to note and the affected accessories: Photo Import iPod nano cannot import photos from an accessory (use iTunes to copy photos to iPod nano). It will not work with third-party card readers or with the Apple Camera Connector. If you connect such a device, you'll see an error message that displays for about a minute and reads, ?The currently attached accessory is not supported by this iPod.? Voice Recorders (Microphones) Like iPod mini, iPod nano does not work with third-party voice recorders. Apple iPod Remote Because iPod nano does not have a remote port, it won't work with any accessory that requires it, such as Apple iPod Remote. Headphones Port Location The headphones port on iPod nano is located on the bottom, therefore, it won't work with any third-party accessory that requires that this port be located on the top. No Video Out iPod nano does not support video out through the dock connector or the headphone port. iPod nano is not compatible with the Apple iPod AV Cable designed for iPod with color display (and iPod photo). If you need to use any of the above devices, you'll need to use an iPod model that supports the accessory. "
Sep 28, 2005 | Apple iPod nano
Apple iPod nano 2nd Generation MP3 Player Logo
103 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
