Question about E-Machines eMachines Desktop PC
Cd dvd door wont open.i push the button to put in cd and nothing happens.i do see a little cd on screen ,then it goes away.
    Novelist:
  • 113 Answers
On the front of most CD or DVD drives there is a small pin hole that you can use to open the drive if it gets stuck. Grab yourself a strong paper clip, straighten one end, insert the straight bit into the hole and push firmly once you feel some resistance.
This will partly open the drive tray to either allow you to remove a cd or insert a new cd or dvd.
Question, Is there a light lit on the front of the drive when you are:
a. trying to eject (instead of using the front button on the drive try using the "Right Click and then Eject" option when selecting the dvd drive in My Computer), If not the drive may be stuffed (broken) or perhaps the 4 pin power connection lead at the rear of the dvd drive has fallen out.
b. is the drive tray sticky when opening or closing? (get a new drive...very easy and very cheap to buy and replace)
Good luck,
Steve (Melbourne,Australia)
Posted on May 14, 2010
Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Feb 02, 2010 | Computers & Internet
Phillips cdr 785 trays wont open
Hi....
Are there small round access holes in the underside of the player (usually with a turn symbol near it)?
Most mfgs put "panic holes" under the unit to get out stuck CDs when the thing wont work right
Also,how old is the unit?
Do you use it alot??
Mar 25, 2009 | Philips Audio Players & Recorders
Cd door won't work
Is there a buzzing noise (motor running ) if so either drive belt failed,or has been put out of time in mech
Jan 14, 2009 | Sony SLV-D251P DVD/CD Player w/Built-in...
CW068 D drawer wont open-it makes a noise like it trying but wont
insert a bent straight paperclip into the little hole on the face. It will manually push a gear to open the tray
Dec 25, 2008 | CyberDrive CW068D CD-RW Burner
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Cannot open cd/dvd player--the player will not come out so i can put a cd on it to play
Use a straightened paper clip or similar thin wire piece of metal and push it in to the little hole on the front of the drive. The door will open.
A thorough cleaning of all parts while the drive is open would probably help, but if it is a laptop drive be careful not to get the electronics wet.
Hope this helps.
Jul 04, 2008 | Toshiba Computers & Internet
My camera wont even turn on
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 01, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Screen is blank
Check to see if the little button that the screen closes down on (which turns off the screen and only the screen) is stuck, or jammed under the little hole that it comes up.  This button is about the size of a pin on most DVD Players, and is located very close to the screen on either side.
Jan 03, 2008 | Mintek MDP-1030 Portable DVD Player
Dvd player won't open
I had the same problem for my panasonic dvd player (ht540). Neither of the above solutions worked so I found this one on the panasonic website:
1. turn off unit by holding down the POWER button for 10 seconds.
2. unplug the power cord and wait for one minute.
3. plug the cord back in and turn on the unit
4. when the dvd begins to play, press "EJECT".
It worked for me. The site for other troubleshooting is:
http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+DVD+Recorders-UCM_PRD_CNT_001989#dvdrec6
Peter
Oct 09, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
E-Machines eMachines Desktop PC Logo
147 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
