Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
I own the 10685, mowed 6 times this year and on the 7th out of nowhere it developed a problem. Primed as usual, starts, runs about 30 seconds, quits. If I catch it in time I can hit the primer again and it will continue to run, again only for a few seconds. Pulled the bowl, blew out the 3 holes in the bowl nut, reassembled the bowl, same thing. Replaced the air filter, and plug, same thing. pulled the carb, blew it out, checked air flow, and gas feed lines for any gum, installed new needle (blew the needle seat out with the air hose,could not find it) seat and spring. Checked the carb for flow and cut off, all is working well, reinstalled the bowl, no change. The carb was clean with the exception of a little gummy strings. The gas is new. If I hold the governor open a little to a higher RPM it will run longer but will still starve out for gas. I'm wondering if it could be the air feed coming from the engine that supplies the carb with the pressure. I cant test it for air flow if the engine isn't running. That seems to be the next step to eliminate. Am I barking up the rite tree? what could it be/
  • 394 Answers
Just a suggestion O.K?
Carefully check the small fuel lines. To and from the bulb. Make sure the bulb fills with gas.( at least two thirds full. ) There is a small fuel filter on the end of a small fuel line in the tank. A small hook of stiff wire will dig that out. Good luck !!!!
Posted on May 14, 2010
  • Wayne Tolonen May 14, 2010
    Hi This is pipecleaner saying I goofed up. The suggestion I gave would have been for a weed eater motor.I apologize for any inconvenience.
I own this same one. Mine stalls out after a few secs if I don't have the mulch plug all the way engaged. It's worth checking to make sure before messing around with bigger stuff.
Posted on May 26, 2010
My craftsman 6.5 starts and stalls like there is fuel delivery problem, i dont know how to get the engine cover off, it runs for a moment after primed then quits i have never had a problem with this mower
Most likely the carb is running out of fuel and not refilling fast enough. Check fuel lines first. Sometimes they break down and can cause blockages in the line. Second, the fuel cap has a vent hole. This hole can get easily blocked with dirt and grim that goes along with lawn mowing. If air cant get in the tank to replace the fuel consumed it causes a vacuum in the tank and fuel starvation.
Jun 17, 2014 | Craftsman Garden
Strange fuel pump issue on FXCW.
High pressure feed from the pump in the tank is rubber and the E20 fuel damages the rubber making it porous so pressure cannot build up to supply the injectors.
Feb 27, 2014 | Harley Davidson Motorcycles
Hi, I have a John Deere Z225 with an 18.5 Briggs
Although, this does sound like a fuel issue due to past experiences I want to say the problem might not be fuel at all, but before we go that route try one thing. On that particular model I believe the gas cap is vented, if so try running it till it acts up, then remove the gas cap for a moment and see if the engine returns to running normal, if not I believe your coil is going out. I have seen alot of these engines recently where the works fine but when the get hot they quit functioning all together or only function part of time which in your case would indicate why it is missing and fowling the plug. When these tend to do this after they cool back down they function properly again until they get heated up again. I hope this helps you.
Oct 03, 2013 | John Deere Garden
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
94 camry won't start after running out of gas?
Fuel injected vehicles will need to be primed when they run out of gas. Your going to have to turn the key on then off at least twenty times leaving it on for five seconds. You may need a half to full tank of gas to get the pump to prime. Another way is to get some carb cleaner, and while an assistant is cranking the vehicle, spray one second then quit for a second then repeat and get the car to start that way and just keep it up until it runs rougher or smoothens out, and let it idle for at least a minute to purge the air out of the system. The key is easier, unless you can figure the relay and bypass the relay to run the pump for at least 30 seconds. That should get it running again.
Jul 17, 2009 | 1994 Toyota Camry
Stalling
I have same mower and just fixed what seems like a similar problem description. I had gone down the fuel system route and the symptoms just didn't add up. Stopped abruptly w/o sputtering once I reached warm-up temp. Replaced the solid state ignition (34443C now part number 3444D). Problem corrected and just mowed my 1/3rd acre w/ no issues.
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Engine cranks, runs for approximately 30 seconds
you nee too take the carb apart and clean it!!!!!!!!!!!!!!
Apr 01, 2009 | Craftsman Garden
Ticking in engine on start up
loud on startup and gone in 30 seconds sounds like a lifter that had de-primed, it can run this way for a long time. what weight oil are you running?
Mar 25, 2009 | 1997 Chevrolet Blazer
Mower will not stay running
Sounds like a lack of fuel. If it has a briggs motor replace fuel pump diaphram in carb.
Jul 19, 2008 | Electrical Supplies
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
467 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
