Question about HP LaserJet P4014n Printer
Need to "hard reset" a P4014n to wipe out admin settings. Admin password was entered in error and now the configuration menu can't be accessed by URL
4 Suggested Answers
cirocpatel
  • 524 Answers
SOURCE: I am unable to reset the admin password on a
To do a cold reset you power on the printer while holding down the go button for about 5 seconds and then release the button. If the button is held for more then 15 seconds it may do a NVRAM reset.
You have to use the software that came with the printer to set it up. Another method if the printer picks up an address from your router would be to type that address in your web browser and then you can make changes. You could perform a cold reset on the printer by holding the go button down while powering on the printer and holding that button down for at least 5 seconds but no more than 15 seconds and it will reset everything to factory defaults which also sets the network card back to autodect where if your network is capable it will assign the address to the printer.
Posted on May 02, 2010
SOURCE: I'm forget admin password on
Cold reset for HP9250C
A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
Embedded Jetdirect IP address
SMTP IP address
LDAP IP address
Embedded Web server password
All control-panel configurable items
The following items are NOT cleared during a cold reset:
Local address book e-mail addresses
Real-time clock (date and time)
Page counts and maintenance counts
Product serial number and formatter number
Service ID
Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Posted on Jan 29, 2011
issken
  • 1472 Answers
SOURCE: HP Laserjet 1320n Admin Password has been
joed_calcule
If you changed the password from the default one but forgot the one you set it too all you really can do at this point is set the printer back to the factory defaults. The menu options below will help you do this.
Advanced Printer Settings
Settings tab
Resets = Change all the printer settings back to the factory default settings.
Let me know if you have any more problems or questions
Issken
Posted on Feb 23, 2010
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Admin
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 09, 2013 | Belkin Computers & Internet
Lost security key to router
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
Jan 02, 2013 | NetGear DG834G Router
Forgot admin password
If the default password on the D-Link has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05) Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
You can now configure the wireless settings. (WPA or WPA2 encryption) Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Nov 20, 2012 | D-Link (DWL-2200AP) 802.11g/b Wireless...
My netgear router on security lock, how do I unlock it?
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 09, 2012 | Gateway Belkin 54g Wireless DSL/Cable...
Forgotten my keyword
reset the router it will wipe all passwords setup again
Jul 26, 2011 | NetGear WGT624 Wireless Router
I need to re-configure my d-link di 624 and I can't get past the username and password screen...?
If the default password has been changed then -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 08, 2011 | D-Link DI-624 Router
How do i find out my wireless router password
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Mar 31, 2011 | Linksys RangePlus WRT100 Wireless Router
Access into setup
Connect a LAN cable from the D-Link to your computer's LANport, open a browser and enter the D-Link's configuration URL. OR open thebrowser on your laptop and enter the D-Link's configuration URL..
http://192.168.0.1
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 28, 2011 | D-Link DSL 500 (DSL-500) Router
How can I reset an unknown admin pw on Linksys RV042 VPN Router? I'm the new IT guy here, and I don't have the admin pw for our VPN router (and I need to provide remote access to a colleage working...
you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router Password: Admin
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router
Apr 16, 2009 | Linksys RV042 VPN Router
HP LaserJet P4014n Printer Logo
2,715 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
