Question about Hitachi Computers & Internet
I bought the Canvio Plus 1 TB portable drive yesterday. I removed the backup and other software, leaving the System Volume Information, and then tried to get Partition Magic to get 2 partitions. It gave me the display "953,867 MB BAD". I then formatted it with quick format (it did not work with Partition Magic, so I formatted it fully) and it still doesn't work. It has the same result with my 2nd PC.
    President:
  • 1,561 Answers
During the process of removing the back up and other software, it is possible that you have removed the software that is useful for the canivio plus 1 TB portable drive and that is why it is displaying virtually all the hard drive bad.
I advice you return it to best buy and complain that the hard drive is malfunctioning, since it is just yesterday you bought it, it should be replaced.
Note, while setting it up, be very careful not delete any important software that might be useful to you.
Take care.
Posted on May 14, 2010
Toshiba HDD not recognized
Could you be more specific ?
on which computer?
which system?
Do you hear any noise?
USB, USB2 or USB3
Jun 15, 2015 | Toshiba Canvio 1.0 TB USB 3.0 Portable...
Can I hook to Samsung TV and play my movies I have down loaded on drive ?
if TV has a usb port just plug it in if not you need another type adapter
Mar 15, 2015 | Toshiba Canvio Slim 1 TB External Hard...
Bought a seagate backup plus hard drive to backup files, installed on computer but cannot backup files, problem says could not be performed because of anI/O device error.
Connect the external drive to a different computer, and try to copy a few files to it. If you still get "I/O Error", then the unit has malfunctioned.
Mar 09, 2015 | Seagate Backup Plus 1 TB USB 3.0 Portable...
How to retrieve data from toshiba 3.0 portable usb storage malfunction
That all depends on how badly the drive is broken.
If the problem is mechanical, suspect a bad connection first. Almost everything else has that as an underlying cause.
If you suspect it has been struck or dropped, there are some tricks to get it spinning long enough to recover the files. Sometimes gentle tapping or drop from an inch or so - no higher! - can loosen things up to get it spinning. Where so-called "stiction" is involved, sometimes alternately freezing and warming the drive can "un-stick" the mechanism through expansion and contraction of the moving parts.
How badly you want the files will determine whether you are willing to pay for a data recovery service.
Only if you are certain that the hardware is working correctly should you attempt to use software utilities in an attempt to repair and recover the file system, most importantly because such utilities need to write to the disk and therefore are likely to write over your files.
The simplest way would be to restore your files from your backup drive.
May 22, 2014 | Toshiba Canvio 1.0 TB USB 3.0 Portable...
Toshiba canvio 1 tb is displaying red where it used to be blue when I click Computer and it's drives.
It sounds like the drive could be full? Right click the drive and select properties. It will show you how much of the drive is used up
Apr 19, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
Error 1920 while installing seagate dashboard on windows xp
This problem is related to RTCHDomain services. If you add admins to the services you can easily solve this problem. To visit the detailed explanation and step by step solution visit the following link - http://www.techyv.com/questions/error-1920-service-%E2%80%98office-software-protection-platform-failed-start
Hope it helps
Apr 05, 2013 | Seagate Backup Plus 1 TB USB 3.0 Portable...
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
My asus oplay air didnt recognizes the canvio USB 3.0 neither cinema tube mini
try to partition it and format in differant filesystem eg. ntfs or fat32
Feb 23, 2011 | Toshiba 10TB Canvio 30 Plus USB 30...
How do I reformat my toshiba canvio 500gb external hard drive for my macbook? If I go to disk utility and erase it, wont it erase the backup software as well?
The disk utility programs should be on the main drive inside the computer...you need to make sure you tell the program which drive you want to erase..Say the external drive comes up as drive "d"..then you want to tell the drive utility software to erase the "d" drive
Dec 25, 2010 | Toshiba Canvio 500 GB USB 20 Portable...
Computers & Internet Logo
88 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
