Question about Maytag Neptune FAV6800AW Top Load Washer
My Maytag FAV6800 will not spin the clothes
The washer seems to go off balance, no matter how many items I have in the washer. It tries to spin then quits.
  • 526 Answers
Here is a Fix if your machine model is a FAV6800A or FAV9800A failing in Spin Cycle with dC/uC unbalance errors.
Fix the Clutch issue and save your 1$K machine. Here is my Clutch Fix post. You can redistribute the wash load in your FAV6800A or FAV9800A till the cows come one and you will continue error out in Spin Cycle of the wash cycle or a Spin Only Cycle. I explain in this post the fix and how to diagnose the issue to the Clutch Pulley One-Way Roller Clutch bearing.
If you just need Clutch maintenance you could be back in service today. You or someone you know can do this and I will help with any questions…………Rich
Posted on May 14, 2010
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you with the not spinning or agitating problems....
Washing MachineMy Maytag FAV6800 will not spin the clothes - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
My washing machine does not spin the clothes dry-clothes are soggy
Was your load a single item or many over full. Many washer will quit so you can rearrange the items so it can spin balanced. The machine will try 10 times to balance the load , if it can;t do it it turns off and waits for you to do it.
Mar 14, 2015 | Maytag Washing Machines
Will not spin the clothes dry it's seem it is not balanced ?
You may have One wet heavy item (one sweatshirt or one bath towel) that is not evenly dispersed within the wash tub, and this will prevent the machine from reaching and completing the spin cycle.
Jul 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Wil not completly drain no code
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Maytag NFW7200TW Front Load Washer
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Off balance spin/poor wringing
CHECK TO MAKE SURE ALL THE SUSPENSION SPRINGS ARE CONNECTED INSIDE THE WASHER. IF SO, THERE IS A SNUBBER UNDER THE WASHER MILKSTOOL THAT IS MADE OUT OF PLASTIC THAT CAN WEAR AND NOT ALLOW THE SUSPENSION TO GLIDE LIKE IT IS SUPPOSED TO. NOT THE EASIEST FIX DUE TO THE BRAKE BEING UNDER HEAVY SPRING PRESSURE. USE CAUTION
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have a washer fav6800 it wont spin code is uc
Un balanced load, This is a machine that should have been re called.Sorry , but its very true.
Jun 14, 2008 | Maytag Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
273 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
