Question about Canon PC-920 Black and White Copier
Start button on 5055 canon copier seen to be stuck; what can be done to reset it
  • 59 Answers
Hi just remove the panel and remove the switching pcb just remove the start button and clean with hot water and dry it then refix the pcb and panel its done.
thanks
Posted on May 14, 2010
I have error sc 00001-01 in my copier canon ir-5055
Check the connector of each thermistor,replace if neccesary.After fixing the problem reset the error in service mode:COPIER<FUNCTION<CLEAR <ERR,and turn machine OFF
Jan 14, 2015 | Canon Office Equipment & Supplies
Canon ir 5055 has an error e000004-0010. how di I fix this?
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
Jam code 0211 in canon ir 5055
Clean or replace roller after fusing unit.(heater) Slide out middle section>Lift green handle on left to expose rollers.
Aug 18, 2010 | Canon ImageRUNNER 1670F Copier
Waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
Scan 5 separate documents into 1 e-mail instead of 5 e-mail
I'm assuming you have pressed SEND button at top.
There is a DIVIDE INTO PAGES button towards the bottom right, if it's a blue colour press it to make it grey, this will send the docs as one file.
Mar 26, 2009 | Canon imageRUNNER 5000 Copier
Installing staples in a Canon imagerunner 5055
Open the finisher door and you will find the place, it is in the front side. Regards
Feb 20, 2009 | Canon imageRUNNER 5000 Copier
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Canon Imagerunner - Priority??
touch add functions key then touch common settings then look for key that says priority
Dec 09, 2008 | Canon imageRUNNER 5000 Copier
Canon PC-920 Black and White Copier Logo
96 people viewed this question
old marine
old marine
