Question about Refrigerators
Kenmore Fridge #596
My refrigerator has a problem between the defrost timer and the compressor i think. i have power at the defrost timer but no power at the evaporator motor fan assembly. the fan in back works fine so i dont believe it is the compressor. Any Suggestions? Thanks in advance.
  • 6 more comments
  • jg5894 Mar 30, 2008
    thanks for the quick reply. When checking the voltage i have power to 2 of the 4 leads at the defrost timer and power to one of the 2 wires that connect to the evaporator motor.(not including the ground wire) There is one wire that goes from the defrost timer to the evaporator motor that is not working. Do you think the problem is the defrost timer or a bad wire? Thanks
    I cant find anything else wrong so i guess tomorrow i will replace the defrost timer and see if that is the problem. If not i will have someone come and take a look at it. They wont have much as far as labor is concerned seeing how i have it taken apart already. Even though i hear the timer working after having the fridge plugged in for 30 min. the dial never moved.
  • jg5894 Mar 31, 2008
    How do i check if it is the defrost thermostat? i think it might be the defrost thermostat. That is connected to the evap motor which was not working. I tested the evap motor and it works on its own. Is it possible that the defrost thermostat would keep the evap fan motor from turning? Thanks for your help dawnn. It is really appreciated.
    well i replaced both the timer and thermostat and no luck. If i bypass the thermostat timer the motor works. Any suggestions?
  • jg5894 Apr 01, 2008
    Well problem solved! Not sure if it was the timer or thermostat. In my fridge which is actually an Amana the thermostat needs to be cold for the fan to come on. So after an hour or so of it being on the fan kicked in. Thanks again for your help Dawnn.
  • frost_prob Jun 09, 2008
    Kenmore #596 with freezer on bottom. Have major frost buildup on heater. Have checked that the heater itself has continuity between ends. Defrost thermostat is visible just above the heater and not sure how to check that. Was going to try to replace the thermostat and the heater timer but cannot find the heater timer. I've looked in back, in refrigerator, in freezer. Any ideas on where to find this would be appreciated.
  • patrick183 Oct 03, 2008
    I have the same problem and I am trying to get the light apart to get to the defrost timer and I am having trouble getting it apart? Any tricks?
  • yogachick911 Mar 28, 2009
    For the past 9 months, I have major ice buildup at the back of my freezer (Kenmore #596 bottom-freezer). My freezer is barely freezing anything at all. I manually defrost it about every 10 weeks (what a mess), and then it is ok for a while. Have been fearful to call Sears - I can't even imagine what it will cost. And I can't find out without knowing the diagnosis - of course. I don't trust them!
    Is this an expensive fix? Appox $$$?
I found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
Posted on Jun 13, 2008
  • 109 Answers
Replace defrost timer and check door switches and defrost thermostat for open circuit, the ground side is what these circuits are switched by.
Posted on Mar 30, 2008
  • 1 more comment
  • CHRIS KLINGER Mar 30, 2008
    the problem is likely to be in the defrost timer, very seldom is it a broken wire, there is something breaking the circuit somewhere. remember to check all of the door switches also. some ge fridges also use the mullion heaters as well to complete this circuit, you can check them with a meter as well for an open circuit. good luck, sometimes these problems can be difficult to locate. if you can't find the open circuit, let me know. there are other alternatives.
  • CHRIS KLINGER Mar 31, 2008
    did you check the defrost thermostat? when cold it should be closed if not it's bad. and the timer should move after 30 minutes regardless.
  • CHRIS KLINGER Apr 01, 2008
    your welcome, yes defrost thermostats need to be cold in order to close the circuit, that's what they do. when they warm up in the defrost cycle they open which causes the heater to disengage.
Kenmore elite 596-76253701 not cold cooling
it could be several reasons. since neither freezer or fridge is cooling i'd think the compressor is not coming on there could be several reasons for this.. id say first it could be the defrost timer is so equipted or a bad start/ run capacitor. these should be checked first. if you are and kind of handy it should not be a big deal.. you must kill the power in the unit befor you work o it though. if theres a defrost timer , locat it and try to turn it a little until it clicks or just turns a bit plug it back it and see if the compressor comes on if so you you need a defrost times. fairly common problem, probably 30- 40 dollars and local appliance parts store. the start capacitor will have to be checked to se it it is working with in the proper rating. if not it will not start the compressor. their cheap usually under 10 dollars at parts store. bet i can tel you from what i see here.. good luck let us know what you find please.
Nov 27, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Can't find the defrost timer on my Kenmore refrigerator 596 series
If you get the complete model number which is located inside the refrigerator on a tag either on the upper left or right wall or the roof inside and then go to partselect.com you will get an illustrated blow out and you'll be able to see exactly where every part is
Sep 05, 2012 | Kenmore Refrigerators
My model 106.53206202 compressor stops working about every six months. The interior light lights so there is power. I unplug the power cord and when I plug the power back in the compressor works fine. ...
I think the defrost timer/control board is hanging up...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Kenmore Refrigerators
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
How to check defrost timer on Kenmore side by side 596-52673200?
You don't have a defrost timer, you have an adaptive defrost control which determines when to defrost based on how often door is opened etc. If you have a defrost problem check , defrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the heater and thermostat are ok it’ll be the control.
Sep 08, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 24, 2009 | Kenmore Refrigerators
FREEZER NOT FREEZING AND FRIDGE NOT GETTING COLD
First check to see if your compressor is running at all. If your compressor is at room temperature you cold control is not supplying power to the compressor. Replace the control or locate the defrost timer and rotate the clutch head screw ( Normally black or Grey) and rotate it a small amount clock-wise. If the compressor then starts replace the defrost timer.
Apr 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
1,579 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
