Question about Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60a20 loses signal
I just bought this tv and I am having a signal problem. I plug the tv into the wall and I can watch TV (cable) for about 3 minutes because it resets itself and then it loses all cable signal including all the inputs such as DVD player and PS3 from component video. I have to unplug it and wait then start the process all over again. What would make the tv lose signal and have to be reset after every minute or two. It must warm up and pop a breaker inside or something. Please help
I had the same problem. The TV would work for about 2 minutes, then lose audio and video for about 45 seconds, then come back on. This was a constant loop. The power LED would stay lit constant though. I considered changing the lamp as other blogs suggested. Then I thought the problem may be simpler. I removed the lamp, and to my surprise, the lamp screen was full of dust. $5 bottle of canned air, cleaned all the dust from the inside of the TV (including the lamp screen), and low and behold the TV worked great. The lamp did have a burned smell to it, but it still worked great. I would suggest trying this first. Save yourself alot of money:)
Posted on Jun 14, 2008
I have a Sony Grand Wega LCD projection tv KDF-E55a20 // KDF-E60A20 The TV's image and audio goes off and on while you whatch tv
Sony LCD Projection TV can do it when lamp is getting really old. When did you replace the lamp last time?
It should be replaced every 2.5 years of average use.
It could be done by user, owner's manual have info on it.
There is a little chance that problem is originated outside of your TV (like issue with cable box).
To eliminate this possibility simply use another source of signal (like DVD player) and see if TV will act the same way.
If it does - 90% chance that lamp replacement will take care of this issue.
Dec 01, 2010 | Sony Televison & Video
While tv is on, at times screen just blacks out ...then comes on remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
While watching the TV the screen goes blank. The LCD light is still good.
If lamp has not been replaced in last 2-3 years, get it replaced now because existing lamp is dying and causing problem.
Lamp replacement procedure is easy and written in user manual of your Sony KDF-E60A20 tv.
Aug 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Where is the lamp on Sony LCD Model No. KDF-E60A20 located in back of TV
There are two thumb screws at lower corners of TV, lose them and take off lower front panel of TV, there you will see lamp cover, unscrew and remove it, lamp is in front of you.
Lamp replacement procedure is written in user manual, click Sony Support to download user manual copy of KDF-E60A20 if required.
Oct 19, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-e60a20 Problem with the tv turning off and on every 15 seconds
go into customer setting and check see that the no signal shut down is tuned of SOny has a problem with that setting and it turns off even with a signal
Sep 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Picture and sound goes out?
does it do it on dvd. if not ists the signal from your cable provider
Jun 02, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
60 inch wide screen sony lcd
Symptom shows its Lamp Replacement time in KDF-E60A20 TV
If you have not replaced TV Lamp yet then change it.
Lamp is available in Part Store and lamp procedure is written in User Manual.
Mar 27, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
61 inch sony LCD projection
Optical block or LVDS cable You need a tech to tell you for sure, have a tech look at it
Sep 30, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60' projection model # kdfe60a20
I finally wet out and bought the tv repair manual. Thought the problem had to be more than the bulb because i was losing sound too. Everything in hte repair manual brought me to the bulb or the ballast. I ordered a replacemant bulb. I spent about 150, which included overnight shipping. I replaced the bulb just before Thanksgiving and haven't had any problems as of yet....
Nov 06, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
