-   i have same problem with my 50h82 toshiba. After turning it on screen
goes green while volume is ok. Whats the solution?????-   ghgrewal
Feb 15, 2009
-   I have a 51 in rear projection hitachi HDTV and for some reason the screen has green lines on it with no picture but you can here the volume of the program playing. Any suggestions to what this may be??-   benshook85
Feb 12, 2009
-   Same problem here. Screen turns green, volume OK, then the TV shuts it's self off. Small red light flashes on front of TV-   rrcn
Feb 08, 2009
-   Volume works, I can check the menu that comes programmed into the tv, but other than that the Screen is completely green. No pictures, Just Green.-   fronglokey
Jan 17, 2009
-   I have a 6 year old mitsubishi 65" rear projection tv and am having the same problem. Its normal for the first hour or so, then the whole screen turns bright green. Volume still works. The tv goes back to normal after turnign it off then back on again.Im afraid something is wearing out. Please help me fix this before it gets worse.-   Guest
I am unable to adjust the multipoint red convergence left and right, but can go up and down. Is it a...
(More)
I am unable to adjust the multipoint red convergence left and right, but can go up and down. Is it a remote problem or the tv?
TV takes a while to turn on. Power light go on then off. have to repeat 3 to 4 times before TV goes...
(More)
TV takes a while to turn on. Power light go on then off. have to repeat 3 to 4 times before TV goes on. RCA D52W19B
I have a sony kp-41t65 tv, I purchased it new in 1998. Today it's acting like a computer screen at...
(More)
I have a sony kp-41t65 tv, I purchased it new in 1998. Today it's acting like a computer screen at is out of whack. The tv screen at the top bowed inward towards the middle in the middle of the screen, bottom same as top but upwards. The colors are out making the letters and numbers look doubled. I realigned them it helped the middle to cear up but top and bottom still the same. If you could help Thank you very much!!!!!!!! Dennis
Have a KP 51WS500 about 4 years old that just started doing this...picture color is normal when tv is cold and first turned on then color starts to shift slightly to yellow/green then back to normal. After about an hour the whole color is off to the yellow/green side but still can see blue where it is supposed to be i.e. sky or blue sign etc. We had to reset the red convergence last year and then a few months ago I noticed the green lines start to appear. Tried to reset the green, and lines disappeared but color is still bad. I'm thinking the whole convergence board is going. Any ideas out there and cost of parts?
after i turned the tv on the screen start turning green and then the hole screen is green but i have sound.please somebody help me with this....
thank you all
