Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson dc07 origin makes a high pitched screeching noise what could be the cause please.
4 Suggested Answers
SOURCE: Dyson DC07 works and cleans fine, but motor makes loud screaching sound.
I called Dyson and they said that the motor needs replacing. I bought it in the UK, and moved it to the US and now am in Brazil. They said they can't service it since it was bought in the UK unless I take it back to the UK since the motors, wiring, etc are different. They said the motor would eventually go out and there's nothing they can do.
Posted on Apr 22, 2008
  • 143 Answers
SOURCE: Hello. My dyson dc04 keeps making a loud screeching noise.
remove base cover by 3 'screws' 1/2 turn anti clockwise and clean well remove fibres replace cover and re try.
Posted on Sep 14, 2009
SOURCE: why does my Dyson animal
I can't probably help you but I can tell you what Dyson told me. I have this same vacuum and it just started making that same noise. When I called their rep they had me take off the bottom plastic piece (comes off real easy by taking a coin and turning the three circles). Check to make sure the belt isn't broke. Then, they had me pull toward me the roller brush and turn it to get it seperated from the belt. Then, take off the belt. On mine, the spindle was full of dog hair clogging it. I took twizers and narrow pliers and pulled everything off. Then put it back together. It worked fine for the next few times I vacuumed then it started again. So, I did the same thing again and found this spindle covered with the hair again. Cleaned it, put it back together and it worked again. Today, while vacuuming I picked up a piece of string and that noised started again. Turned it over and saw that string on that spindle. Took it off, cleaned it and it worked again then started the screeching again. So, tomorrow I am calling a vacuum repair place. IF you have the same vacuum (which you do) it should still be under warranty. Dyson told me I would have nothing to pay unless I abused the vacuum which I did not. Hopefully I am not without it very long...I have two golden retrievers who do shed alot.
Posted on Nov 27, 2010
Dyson high pitch noise
Dear Tasha ,
I suggest that you clean out the tubes and see if any paper has been rolled into the bottom. P.S. Do you know how tall 170 cm is in feet.
Feb 25, 2014 | Vacuums
Dyson dc07 is making weird noise
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC07 is making a popping noise in use. Unusual noises can be caused by a number of different issues, and in order to determine exactly what's causing this we would need to hear it. I'd encourage you to call our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). One of our experts will be able to listen to the machine over the phone and diagnose the cause of the issue.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi, my dc07 cleaner has developed a very high pitch screech its not a constant sound but intermittent and last for a second or two and is very unpleasent, its a loud cleaner anyway but this noise is so...
hi.
it sounds like the bearings in the motor are worn out. the only solution is to change the motor, or the entire hoover. motors are available from ebay for about £35 and it will then need to be fitted. unfortunately these bearings do wear out eventually. once they start to make screeching noises like this, there is not much life left in them, and they will get worse rapidly.
if you decide to change the motor yourself, please feel free to ask for more details on how to do it.
hope this helps
Aug 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 makes loud vibrating loud noise
Sorry to hear about the problem you're having with your DC07. Your cleaner is equipped with a safety feature which makes a ratchet noise if the brushbar gets jammed, to warn you to clear the obstruction.
For help checking for and clearing obstructions, you may find it useful to visit www.dyson.com and click on 'Support'. This step-by-step illustrated guide shows you the easiest way to clear the brushbar:
http://www.dyson.com/support/help.asp?article=5&product=DC07-SY-HEPA_US
If you've followed this walkthrough and your DC07 is still making a ratcheting noise, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide you with the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Jul 25, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson us making a high pitched noise and centre isn't spinning
Ours did the same thing, may actually be covered under a extended warranty, if you bought one. There is a little gear like disc underneath a round black cover on the bottom, it actually separates the roller into two parts, I am talking about the roller on the bottom with the brushes on it. It looks like one piece, but is not.
Mar 03, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I am losing suction and it sounds as if there is a leak in the vacuum(I hear air rushing around). There is also a high pitched noise. Dyson dc07. Can there be leaks in the gaskets where you clean hoses and...
It wont be a gasket problem - they don't tend to fail.
A high-pitched noise can be a number of different things. That is too vague to diagnose on here with the description you have given. Can you be more specific?
Jan 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
High pitched whining sound when vacuuming. Stops when handle is in an upright position. Thank you.
the high pitched whining is most likely the belt and it stops when you put the handle up because the roller bar is not engaged when you put up the handle.If it is the belt making that noise it will most likely break soon and you will need to put a new one on. Hope this helped...good luck
Oct 07, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Ball makes high pitched noise
Hello, this is Ava with Think Crucial.
To fix any noise issues that your Dyson vacuum gives, a proper maintenance will do the trick. Most of the time , cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. Please refer to your operational manual how you can do this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 04, 2009 | Dyson Vacuums
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
563 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
