Question about Epson Aculaser C1100 Printer
Espon aculaser c1100 service req e511 - Epson Aculaser C1100 Printer
  • toneruk300
    toneruk300 Jul 01, 2012
    If you get a pair of pliers and turn the brass ferrule a half turn the drum unit will come apart place to one side in a dark cover .Then on the main body move the black transfer belt equidistant on the rollers .Replace the drum unit and try again
  • 186 Answers
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
Posted on May 22, 2010
  • dan7816 Apr 02, 2011
    WOW! I can't believe it was this simple to fix. When I found out how from an Epson service centre what the cost was to fix this, I bought a new printer [kyocera 5200DN]. The only reason I'm fixing this epson is to salvage it and sell it. I wish I'd spent more time researching earlier. cheers.
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
Printer displaying "Service Req E511" and wont print
Error E511 relates to the PCU (not detecting the transfer belt rotating).
This appears to be common. Sometimes the belt can slide on the rollers to the left, thus the square metallic reflective spot on the belt does not pass over the TR0 sensor, no amount of cleaning will cure this, you either need to strip the top cover off hte PCU (6screws) and pull the belt back over to the left or replace the PCU all together. BTW PCU stands for Photoconductor Unit if you didn't know.
Aug 17, 2010 | Epson Aculaser C1100 Printer
Error: service reg E511 what does this mean?
Part of the photoconductor unit known as the transfer belt is not being detected when the E511 Service Requested error comes up. Epson in the UK has the troubleshooting outlined here:
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support;jsessionid=035E9EA2127A8A5A478481112D9F98B2.acc2?target=article&extn=.html&articleId=1319
Jun 19, 2010 | Epson Aculaser C1100 Printer
Service Req E511
e511 is to do with the photoconductor unit which sits under the top lid
usually detector underneath the photoconductor dirty or the wide rubber belt then runs throuigh the photoconductor is sligthly off to one side
Feb 24, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
Error: service req E511
Possible parts that caused the error
􀂆 Troubleshooting
􀂄 Photoconductor Unit 􀂄 SENSOR TR-0
􀂄 HARNESS-ASSY XERO 􀂄 MOTOR ASSY P/R
􀂄 HARNESS ASSY MAIN 􀂄 PWBA MCU
􀂄 LV/HVPS
Dec 30, 2009 | Epson Aculaser C1100 Printer
I've a notice in epson aculaser 1100 lcd (service reg E511)
The E511 error for your Epson Aculaser  in most cases means that its motor has malfunctioned or something is preventing the motor from working properly.
Jan 26, 2009 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer suddenly stopped printing
To my knowledge Error Code E511 refers to photoconductor and/or its associated components. It is possible that:
  • the photoconductor requires a bit of cleaning and to be reseated snugly;
  • the black rubber conveyor (transfer) belt inside the photoconductor moved away from its path;
  • the silver square reflector on the transfer belt needs cleaning;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
2,475 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
