Question about LG Heating & Cooling
What is the recommended distance between inner and outer unit of split air conditioner''.
  • 674 Answers
The unit comes precharged with enough refrigerant for the unit and a given amount of line set ( the copper pipes that run from the outside to the inside unit). The installation instructions will tell you how much line set the unit is charged for. If the line set is shorter or longer refrigerant can be removed or added to account for the difference in line set. Some people just install the amount of line set the instructions state and roll it up if it is too long.
Posted on May 14, 2010
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
Need to remove coleman air conditioner from unit and re seal. I have it apart but it is not coming out of hole.
The installers may have used dynabolts or plugs to hold the outer frame into the wall opening. You will have to slide the inner part of the machine out to access these. ( I assume its a wall / window unit?)
Aug 21, 2013 | Coleman Heating & Cooling
How much psi to charge on a split unit which has a distance of 40 meters between the indoor and outdoor unit
the psi of an air conditioner is not 'changed' by the distance of the line set to the indoor coil. the psi will remain constant depending on type of refrigerant used, i.e. R-22 or some of the newer refrigerants.
For example - when using R-22 - the low side will typically run at around 70 psi give or take a few pounds depending on conditions while the high side pressure will be determined (as always) by adding 35 degrees to the ambient temperature and finding the corresponding psi on the gauge.
Aug 06, 2011 | Heating & Cooling
My LG Split 1 ton Continue poor working with under voltage 180V (Due to Long distance Transformer), Once its capacitor have to change this summer. Now i arrange Stabilizer which give 230V. Before...
Unfortunately, there is not a great deal of information about LG splits available, but is you are talking $12,000 to to repair, then it is much cheaper to replace since a two ton complete is less that half that amount.
Jun 30, 2011 | Heating & Cooling
AMCOR 24,000 BTU split system. Worked fine two years, then today it had no power. Checked circuit breaker, it had popped. Reset CB and went to inside unit - would not turn on or off with remote or hard...
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Aug 09, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Location of compressor to wall hung unit
According to the manufacturers spec sheet the 1.5 ton unit can have a max line length of 100'. This info was obtained from http://dl.owneriq.net/b/ba099899-54f3-45d6-a374-1ce6d249205a.pdf
Hope this helps.
Jul 24, 2010 | AmcorAire UCHW-H18AF2 Split System Air...
I buy air conditioner mark haier after 3 years the compressore its failer, when replace the compressore and compleate the air conditioner i hear high sound in the outer unit such us the flowing of flow...
If unit was not evacuated after compressor change out it is possible to have are in system. Gas needs to be reclaimed, and evacuated with vacuum pump ,and recharged. Rus
Nov 04, 2009 | Heating & Cooling
I got a sam sung split A/C while switch on the
just check the gas pressure and gas pressure is ok,may be out door unite is blocked.do the high pressure service
Oct 17, 2009 | Samsung AS1293L Air Conditioner
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
Ramsond split AC 12000
HI YOUR BROBLEM I THINK IS THE SENSOR FOR THE ROOM TEMP
Sep 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
64 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
