I have an Acer screen, about 1 year old. For some strange reason my screen has come up with a yellow/green tinge to it. Not easy on the eyes. Can I fix this problem myself or is it something that an expert needs to sort out? Many thanks Wayne
    Scholar:
  • 50 Answers
Hello wayne,
If this is a CRT screen. . then this applies.
if you have discoloration on your CRT tube monitor (due to a magnet being place near the actual tube), (i.e Speakers)
Most new Monitors have a magnetic degaussing circuit built in the Click the Menu button on the monitor and look for "Degauss". If that doesn't fix the problem.
or check this out for more reference: metacafe link
good luck,
DjEnigma
Posted on Mar 30, 2008
Yellow tinge to whole tv screen
if a crt type set a bad solder connection or connections are present at end of the crt on that board there.
Jun 11, 2012 | Philips Televison & Video
Acer X193HQL LCD Monitor Colour Problem
Hello Sales, hi, try to reconnect the VGA cable from the PC, and wiggle it a little and see if the green tinge thing disappears on screen, if it does there are loose contacts, you can also try to replace you VGA cable, see if it solve the color problem.
Apr 27, 2010 | Acer AL1912 19" LCD Monitor
Samsung hc-p4252w - yellow tinge on left side of screen
If you put magnet speaker ( Standard speaker) near the TV, first you must move that speaker away from your TV because this will cause your colour TV screen color scattered. Then switch off your TV for 5 hrs. then switch it ON again your problem will be solved if the degaussing coil working.
Jun 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Problem with the InFocus IN1 Gaming Projector (when recieved) - No red, constant yellow tinge and constant lines.
It is because the xbox 360 is set to 60hz, change it to 50hz and it will be clear like it's meant to be. However, some 360 games are 60hz so for those games the quality is not good.
Aug 10, 2008 | InFocus IN72 Multimedia Projector
Dvd player plays with yellow tinge
If you are using a scart connection, check that it is plugged in fully & straight, also check for bent or missing pins.
Sounds like you have no green input.
Jun 06, 2008 | Televison & Video
32" Toshiba television Mod. 3357DB
If im not mistaking I remember the toshiba 32" to have an on screen alighnment in the sevice menu.. and I would not recomend that anyone without the proper manual and tools to fool with these adj as I've seen in the past that a set had to be completely redone even the tuner alighnments after someone went in and tryed to adj the set., Now the green tinge you speak of is the CRT getting weak The best way to ajust this would be to see if on the picture tube pc board on the end of the Picture tube if it has any little control on it ? if it does look for the green drive and put on a b&w Picture. slowlty turn down the green drive control untill the pic look almost B&W and you probably wont be able to get perfact grey scale as the crt is weak . If theres no controls on the crt pcb then your gonna need a service alighnment manual and adj the green drive that way. Good Luck
Apr 24, 2006 | Toshiba 32A60 32" TV
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
