Question about Cam Spray 1500A 1450 Psi Cold Water Electric Hand Carry Pressure Washer
My pump is leaking and i took the manifold off to check the o-rings and they seem to be fine and now i am trying to take the valve caps off to check the o-rings in there and cant seem to get them off how do i go about doing that.
    Problem Solver:
  • 4 Answers
It is probley the connection is loose or a gasket need replasing
Posted on May 14, 2010
Check engine code po442
Most likely causes
  • A loose or improperly affixed gas cap
  • A non-conforming gas cap (i.e. not factory/original brand)
  • A small leak/hole in a fuel vapor hose/tube
  • Other small leak in EVAP system
  • Faulty vent o-ring seal
  • Defective vent valve
  • Defective purge valve
  • Defective leak detection pump
  • Jul 05, 2014 | Jeep Grand Cherokee Cars & Trucks
    2002 mountaineer v6 car will start n try to idle then die scanner said bad oil sensor changed that n no change checked fuel pressure it fine checked volts to coil pack n it's fine ?? Frustrated
    i would check the throttle position sensor first, check for vacuum leaks, egr valve, i read a few things were people talking about a o ring under the separator. which is under the intake manifold. i would check the easy ones first before pulling your intake manifold off
    Mar 12, 2014 | 2002 Mercury Mountaineer
    Fuel pump leak
    Looks like it may be a fuel return line from the fuel manifold . It may be split or loose . Probably both . Get a new section of fuel hose and some good clips and replace it
    Feb 22, 2014 | Acura Cars & Trucks
    Rough idle on 2001 dodge stratus 2.7. Threw code P0303 so i replaced the ignition coil and is now throwing the code P0442. After fixing the ignition coil and resetting the computer it ran great for about...
    A loose or improperly affixed gas cap A non-conforming gas cap (i.e. not factory/original brand) A small leak/hole in a fuel vapor hose/tube Other small leak in EVAP system Faulty vent o-ring seal Defective vent valve Defective purge valve Defective leak detection pump
    Read more at: http://www.obd-codes.com/p0442
    Oct 16, 2013 | Cars & Trucks
    Hi, I have a scanner cause engine light is on, shows vacuum leak large. tried new gas cap, cleaned filler tube where gas cap contacts, replaced a plastic tube from valve cover to air filter hose. tried to...
    what code is it?po440,p0455?If it is one of those codes it means you have a large evap system leak not a vacuum leak by the engine.the evap leak is most likely a inop vent valve or a fuel cap not properly sealing.
    Apr 13, 2011 | 2005 Chevrolet Uplander
    Having the same problem on a 2005 4.3l....... replaced plugs, dist. cap, coils, and cam sensor. o2 sensor is good. idles great till you push the gas, then it misfires. timing was checked it was fine. ...
    Something is probably leaning out the mixture when you open the throttle. It seems that any ignition issues have been ruled out.
    So, check the following: fuel filter clogged, low fuel pump pressure, the fuel pressure regulator could be stuck at the idle setting, the EGR valve could be stuck open, faulty throttle position sensor (TPS) or circuit, faulty manifold absolute pressure (MAP) sensor, faulty or dirty manifold air flow (MAF) sensor, faulty intake air temperature (IAT) sensor, and an air leak into the intake duct or manifold between the MAF and the throttle body. I think if the intake manifold gasket had a leak, it would be misfiring at idle.
    Ask the shop if any of the above checks have already been accomplished. I'll bet most of them have, but one may have been overlooked.
    Feb 25, 2011 | 1998 Chevrolet C1500
    Po 442 po 455
    P0442 - Evaporative Emissions System Leak Detected (Small Leak)
    P0455 - Evaporative Emissions System Leak Detected (Gross Leak)
    This diagnosis detects leaks in the EVAP purge line using engine intake manifold vacuum. If pressure does not increase, the ECM will check for leaks in the line between the fuel tank and EVAP canister purge volume control solenoid valve under the following vacuum test condition. The vacuum cut valve bypass valve is opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP canister vent control valve will then be closed to shut the EVAP purge line off. The EVAP canister purge volume control solenoid valve is opened to depressurize the EVAP purge line using intake manifold vacuum. After this depressurization is implemented, the EVAP canister purge volume control solenoid valve will be closed.
    Causes:
    - Missing Fuel cap
    - Incorrect fuel filler cap used
    - Fuel filler cap remains open or fails to close
    - Foreign matter caught in fuel filler cap
    - Incorrect fuel tank vacuum relief valve
    - Leak is in line between intake manifold
    Solutions:
    - Re-tighten or replace fuel tank filler cap
    - Replace damaged or leaking EVAP canister
    - Replace damaged or leaking lines.
    Feb 10, 2011 | Chrysler Town and Country Cars & Trucks
    I have a Samsung AQV12JA. Fault code (Gas leak) have replace the outdoor and indoor thermistor per tech line. They said replace outdoor computer board. Board was back ordered for over a month, this is a...
    As per the error code there should be gas leak from the Air Conditioner. Please visit the link below for a complete service manual with diagrams for more details, I hope it should help:
    http://tinyurl.com/23ufvr2
    Thanks and regards,
    Anil.B.R
    Sep 07, 2010 | Samsung AS18A6RB Air Conditioner
    Engine blowing oil from oil filler cap
    I had the same problem. I changed the pcv valve and checked the hose. It still did the same thing. Then I checked the metal tubing that the hose connects to and found it was full of hardened gunk. I sprayed PB Blaster into the tube let it soak for awhile. Then took an old choke cable, put it on a drill and ran it into the tube like a drain snake. It took a while of doing this over and over but eventually got it cleared out. Now, no more oil all over the engine and hood compartment.
    Dec 12, 2008 | 1990 Jeep Wrangler
    Thick blue smoke. no oil leaks new spark plugs and spark plug wires. checked all cylenders cant figure out why its smoking.
    Hi! Chris, There are many causes of oil burning or exhaust smoke. There are three different causes of normal oil burning, 1; worn valve guides (smoking during deceleration), 2; worn cylinders and piston rings (smoking during acceleration), 3; split or worn out valve seal, or damaged intake manifold gasket (smoking all the time). Of course there are several variables in this equation. Sometimes coolant can also get into a cylinder and cause a blueish smoke. If you remove the spark plugs and use a pressure pump on the coolant system (radiator), coolant should leak into the intake manifold or cylinder. Coolant leaking into the intake manifold will leak into several cylinder through the valves. So, what year and how many miles are on the Jaguar?
    Aug 08, 2008 | Jaguar XJ6 Cars & Trucks
    Cam Spray 1500A 1450 Psi Cold Water Electric Hand Carry Pressure Washer Logo
    116 people viewed this question
    Top Cam Spray Garden Experts
    John Trevino
    russlakeside
    Level 1 Expert
    Are you a Cam Spray Garden Expert? Answer questions, earn points and help others
